Introduction: How to Convert a Case Fan to USB
In this Instructable I will show you how you can convert an old case fan for a pc to usb power.
Step 1: Materials Needed
For this project, you will need:
A pc case fan
scissors
a usb cable (doesn't matter what the end of the cable is as long as one end is a full size male usb jack)
a wire stripper and electrical tape
A pc case fan
scissors
Step 2: Cut Fan Connector
The start of our journey is to use your scissors to cut the connector off of the case fan.
Step 3: Strip Fan Wires
Now we need to strip the ends of the black and red wires with your wire stripper. If you want, you can cut the other wires short so they stay out of your way. We will not be needing them.
Step 4: Cut Usb Cable
Now cut the end of your usb cable that is not male off.
Step 5: Strip Usb Cable
Now you need to strip the usb cable to reveal the shielding. peel back this shielding to reveal the red and black wires. You can cut the other ones, as we don’t need them.
Step 6: Strip Usb Wires
Next, you need to strip the red and black wires.
Step 7: Twist Wires
Now we need to twist the red wires together and the black wires together. Make sure to tightly twist them so you get a stable connection. If you want to take this a step further, you can solder the wires instead of twisting them, but twisting the wires should be enough.
Step 8: Tape It Up
Now you should individually tape up the black connections and the red connections. Then you should cover those in a layer of electrical tape as shown. If you want a cleaner look, you can use shrink wrap over the individually wrapped wires instead of tape.
Step 9: Test It
Step 8 is to simply plug it in to either your computer or a usb charger to test it. (The fan is actually spinning in the picture)
Step 10: Enjoy
Have fun staying cool with your new USB fan!
