Introduction: How to Analyze a BSOD Crash Dump
Blue screens of death can be caused by a multitude of factors. There are many tools on the internet that can analyze these; however, Microsoft has its own tool. When a computer is exhibiting problems, most users are reluctant to download a 3rd party tool that "might make things worse." This is where the Windows Debugging Tools come into play.
23-12-31Update!
Microsoft has made the tool available for download without having to install it as part of a package. WooHoo! This package, according to their documentation, only works with Windows 10/11. I am currently running Linux, so I cant test it. ( side note: If you want to try Linux, id highly recommend this https://fedoraproject.org/spins/kde/ It's a Fedora spin called Plasma. Its a lot like Windows, but its ultra stable and secure out of the box, let me know if you're interested or need help.) I might make a tutorial; however, we are talking about Windows now, here's the link: https://learn.microsoft.com/en-us/windows-hardware/drivers/debugger/Download the tool and continue from Step 4.
This How to Will Instruct a User on How to Install the Tool and How to Analyze a Crash Dump to Determine the Cause.
Step 1: Download the Debugging Tools for Windows
- Windows 7 and Newer: Navigate to the Windows Dev Center to download the Windows Software Development Kit downloader. This is not the tool, its only the downloader for the tool.
- Windows Vista and XP: Download the Microsoft Windows SDK for Windows 7 and .NET Framework 4 as .NET Framework 4.5 is not supported on Windows XP.
Step 2: Run the Setup for the SDK
- Click Next through the installer until you reach the screen that downloads the packages, labeled: "Select the features you want to install."
- Deselect all the checkboxes next to all the packages except Debugging tools for Windows
- Click Install.
Step 3: Wait for the Installer
Step 4: Run WinDbg
- Run Windbg as administrator. The screenshot is from Windows 8.1, but this step is the same for all Operating systems Vista and higher, run as Administrator.
- On Windows 8.1, this is achieved by searching for the program, then Right Clicking it in the list to the right.
- It is important that Windbg be ran as Administrator.
- On Windows 8 and higher machines, there are permission issues reading crash dumps when the user isn't elevated.
Step 5: Set the Symbol Path
- Click on File
- Click on Symbol File Path ...
Step 6: Input the Symbols File Path
- Paste the following text into the Symbol Search Path Dialog
- SRV*C:\Windows\symbol_cache*http://msdl.microsoft.com/download/symbols
- Click OK
Step 7: Save the Workspace
- Click on File
- Click on Save Workspace
Step 8: Open the Crash Dump
- Click on File
- Click on Open Crash Dump...
- Navigate to: C:\Windows\
- Select the file named MEMORY.DMP
- Click Open
Step 9: Analyze!
- At the bottom of the wall of text, you will notice a line with the text:
- Probably caused by :
- If you can imagine, thats what caused the BSOD.
- Google the thing that caused your bsod
- For example: In this instance i would google
At the bottom of the block of text, there will be a blue link with the words !analyze -v
- Click on the blue link named !analyze -v
- This will give a further detailed analysis to post on a forum, or send to someone else.
- It will also tell you what kind of fault it was, in this instance, my bsod was a
- DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
Step 10: Optional: Save the Output
- Click on Edit
- Click on Write Window Text to File...
- Choose a location that is easy to remember, such as Documents.
- Share the text file with people that can help!
- Done!
