Introduction: How to Build an Outdoor Hammock Stand $25
About: Hey! This is Molly and Dylan from the YouTube Channel Woodbrew:) We started a custom furniture business after high school and that has turned into creating DIY content online.
What to see more projects? Check out our YouTube Channel:) https://goo.gl/2s5Mwt
Materials Needed: (affiliate links)
Tools Needed:
Step 1: Cut Your Boards to Length
Follow the cut diagram above to make all your cuts. All the angles are 25º and be sure to orientate them the correct way.
Step 2: Assemble the Two Arms
Use the Yellow and Red pieces to create the arms. Sandwich these boards together using some Timberlok screws.
Step 3: Assemble the Frame
Use the color coded diagram to help with the assembly. Use more 4.5" Timberlok screws.
Step 4: Add the Feet
Flip over the frame and add your two feet. Be sure to center these to the frame.
Step 5: Add the Supports
Eye ball a good angle and screw these in place. All that matters is that this section looks good. They just add support to the frame. Be sure to step back and make sure you are doing each side the same.
Step 6: Add the Eye Screws
Use Stainless steel eye screws here. Pre drill and use a screw driver to screw them in. We used these: http://amzn.to/2u2GdEK
Step 7: Move Into Place
Find a nice place for your hammock and Relax! Your All DONE!
Beat the Heat Challenge 2017
Runner Up in the
Outside Contest 2017
Runner Up in the
