Introduction: How to Change Spark Plugs in a Car
Spark plugs: Is a mean to ignite Mixture consists of fuel and air
Frist of all there a problem if you don't changes the spark plugs which is :
1 – The engine of the car going to be weak.
2 - The engine take a lot of fuel because the engine doesn't work correctly.
Step 1: Need Several Thing
So, be sure you work on change the spark plugs, to do it you need several thing as shown bellow :
1 - Alanki Size 5mm .
2 - SPANNER size 10 like that one on the photo.
3 - Socket gasket .
4 – Spark plugs .
Step 2: Open the Screws
Use a lanke to open the screws counterclockwise to take off the caver.
Step 3: Disconnect the Coil
After open the caver we can see the spark plugs and
disconnect the coil .
Step 4: The End
Using the spark plug wrench, continue tightening. Make sure the plug is in firmly, but do NOT over-tighten it.
