How to Color Wood, Method 1
2,547
47
6
About: A wife, mom, and maker, making heirloom quality wood artwork for the bold home.
One of my favorite parts when working on a piece, is adding the finishing touch, usually a pop of color. There are really three tried and true ways of adding color to a wood piece: painting, dying, and staining. Both painting and staining are chemical mediums which contain pieces of pigment that sit on top of the wood. Paint has large pieces of pigment, which, when applied generally totally obscure the wood grain, unless it is greatly thinned with a paint thinner such as mineral spirits. Stain is also a medium that contains pieces of pigment, but smaller pieces of pigment which will not totally obscure the grain. However, in both cases, paint and stain, the pigment is sitting on top of the wood, meaning with a bit of sanding it can be totally removed. With dye though, a chemical reaction is occurring between the dye and the fibers of the wood, completely altering the color of the top layer of the wood. You can still sand to remove the dye, but it will require a great deal of time and work to do so. The best part about the dye is because its not a pigment that sits on top of the wood, you can see the full grain of the wood, its color has just been changed.
This instructable is the first in a series that will go through several different methods for dying wood. For method 1 I will be covering the use of FolkArt dye by PlaidCraft.
Step 1: Step 1 - Gather Supplies
For this first method I will be using FolkArt Dye from
PlaidCraft. You can purchase this dye at any Michaels store or use the link below. Here’s what you need to get started:
1. Piece of wood to dye
2. FolkArt Dye
3. Nitrile Gloves
4. Cotton rags
5. Disposable cups
6. Stir stick, as applicable
7. Piece of cardboard
Step 2: Step 2 – Prep Work
You will want to make sure what ever wood project you are dying is sanded to 180 grit at a minimum, and 220 grit is preferable. FolkArt Dye is a water-based dye which will raise the grain of the wood after application. If you choose to add water to the dye to thin it a bit, which we will get to, it will raise the grain even more. Now, if you are going to add a top coat such as lacquer, I would not worry about the grain being raised. However, if you’re going to have no top coat, or you’re applying another water-based product as your top coat then it is best to use a damp cloth or a small spray bottle to get the wood slightly wet to raise the grain and sand it with 220 grit sand paper prior to applying the dye to avoid the dye raising the grain.
Step 3: Step 3 – Prepare the Dye
Okay, now its time to prep the dye. You can get FolkArt dye in an array of different colors. All of them are pretty bold and bright. You may choose to take one of their colors and use-as-is. One of my favorites to use-as-is is the teal. You may also choose to do a little mixing of a couple or many of the colors to come up with your own hue. It is completely up to you. Either way, you will want to put your dye into one of your disposable cups. If you are mixing multiple colors together you will want to use a disposable stir stick.
Now the next thing you need to determine is whether to thin it with water or not. If you apply as is, without thinning, you will absolutely still be able to see the grain of the wood. However, like I have stated, the colors are very bold, and because of that, they can distract from the grain pattern. So, if I have a piece of wood that has some very unique grain patterns, such as a piece of spalted wood, I usually decide to thin the dye down with water, just so the color adds to the pattern of the grain, not distract from it. To thin it, just add water to the dye in the cup and mix.
Step 4: Step 4 – Apply the Dye
Lay down a piece of cardboard on the table you will be using to dye your project. The piece should be big enough for the piece you are dying along with the cup of dye and the cotton rags. Place your piece of wood, your cup of dye, and your cotton rags on the cardboard. You will want at least two cotton rags. Put on a pair of Nitrile gloves to keep from dying your hands. With one cotton rag, dip it in the dye and apply it to your piece of wood. I like to apply the dye using a circular motion with the rag. Apply the dye to all surfaces of the wood you would like to color. With the clean rag, remove any excess dye from the wood. Leave your wood piece on the cardboard to dry. Let the piece dry for at least two hours before applying any additional finish.
Step 5: Step 5 – Rinse, Wash, Repeat…..or Not
Once the dye is dry, assess if you are happy with the shade of the color. If you want it darker, repeat step 4 and apply the dye again. If you are happy with it, move on to step 6.
Step 6: Step 6 – Apply a Top Coat
You will want to apply a top coat to your wood piece to protect the wood and to protect the color. I recommend using a top coat that is clear to allow the color to shine the most. I would also recommend either going with lacquer or a water-based top coat such as a water-based polyurethane. You can use an oil or oil-based top coat if you choose, however, oil tends to add a bit of yellow on top of the color. Also, because the dye is water-based, applying an oil-based finish on top can sometimes leave the finish looking a bit blotchy I have found. There are ways to fix this of course that I will cover in another blog. For now, if you stick with lacquer or a water-based finish you will be all good.
Step 7: Finale
Here is a quick video that demonstrates the whole process, from planning, through sanding, to dying.
    • 1 Hour Challenge
      1 Hour Challenge
    • Backyard Contest
      Backyard Contest
    6 Discussions
    Stupidassol
    Question 7 months ago
    Here's the stupid question, you knew there was going to be at least one. Where do you obtain wood for this? I am thinking your standard run of the mill oak, cedar, etc. isn't going to be as nice as the piece you have shown. Also, are there any considerations to take into account if the wood one chooses is a soft or hard variety.
    Thanks for the instructable!
    1 answer
    FreemanF1Stupidassol
    Answer 7 months ago
    Good question! So this piece of wood is spalted oak. I purchased it from a local saw mill. That's where I would suggest looking for any wood, at a saw mill versus a big box store. I would think the biggest consideration is whether you choose a closed or open grain type of wood. A more closed grain wood will allow the color to be more consistent across it. The open grain will show different affects with the dye, and may allow a situation where you can layer different dye colors. Its a bit of experimentation. sorry for the not so super concrete answer.
    PixyMcCrafty
    8 months ago
    Amazing work, I love the dye technique, looks fairly simple and inexpensive. Definitely something I need to try!
    FreemanF1PixyMcCrafty
    Reply 8 months ago
    Definitely simple and pretty darn inexpensive. Most expensive part on the tray project were the handles. The dye doesn't cost too much and you need very little to get the job done.
