How to Make DIY MARBLE Run Machine From Cardboard Science Project at HOME
1,187
23
DIY Ocean is a channel where you can find cool 'How To' projects and crafts made out of cardboard...
Materials you will need-
-Cardboard
-Cutter
-Glue
-100 RPM DC Motor
-B.O. Motor wheel
-DC motor speed controller
-Battery
-Coloured card paper
-Tape
-Foldable cardboard
-Long wooden sticks
Teacher Notes
Step 1: Take a 50cm * 20cm Piece of Cardboard. Place a Cardboard Cutout of the Measurements As Shown, on It.
Step 2: Place the 100 RPM DC Motor As Shown. Cover Both Sides With Cardboard Pieces.
Step 3: Take the Inside of the B.O. Motor Wheel, and Glue It to a Circular Cardboard Piece As Shown. Place This on the DC Motor. Now, Place a Cardboard Cutout As Shown.
Step 4: Take a Circular Cardboard Piece With 30cm Diameter, and Make the Cuts of the Given Measurements. Take Another Circular Cardboard Piece of 20cm Diameter and Make Similar Cutouts.
Step 5: Place the Circular Cardboard Piece Over the Wheel and Make Sure There Is a 5mm Gap As Shown.
Step 6: Place Cardboard Cutouts As Shown in the Following Images. Now, Place the Circular Cardboard As Shown. Cover the Front With a Circular Cardboard Piece of 10 Cm Diameter.
Step 7: Make the Connections As Shown Between the Motor, Battery and Speed Controller. Place the Battery and Controller on the Cardboard and Cover It Up As Shown.
Step 8: Take a Circular Coloured Card Paper of the Given Measurements, Cut It As Shown to Make a Funnel Type Shape. Apply Tape on the Cut.
Step 9: Take a Circular Cardboard Piece of 14 Cm Diameter, and Make a 12 Cm Wide Hole As Shown. Remove the Upper Layer of the Cardboard.
Step 10: Cut at Regular Intervals of the Card Paper. Fold Through the Cuts As Shown. Now Stick the Circular Cardboard As Shown on the Paper. Make 2 Such Pieces.
Step 11: Take a 2.5cm Wide Foldable Cardboard and Roll It Around the Circular Cardboard. Insert the Long Wooden Sticks Through the Paper As Shown.
Step 12: Use Small Cardboard Pieces to Fix the Sticks on the Cardboard As Shown. Cut the Extra Portion of the Sticks and Apply Super Glue to Fix Them.
Step 13: Make the Marble Flow As Shown in the Following Images.
Step 14: Label As Desired. the Marble Run Machine Is Ready!
    • Make It Fly Challenge
    • Stone Concrete and Cement Contest
    • Games Contest
      Games Contest
    Gadisha
    6 months ago
    Very nice, I like marble run machines :)
