Introduction: How to Make Galaxy Shoes
goal - to make galaxy shoes that are cool and they are for any ages
materials
-newspaper
-black shoes
-sponges
-paint brush set,fine tip paintbrush
-paper plates
-tooth brush
-tape
-paint-black,dark blue,purple,red,white,pink,light blue
Step 1:
First, you will have to remove the laces from your shoe.
Step 2:
Second, you will have to stuff one page of newspaper in the shoes.
Step 3:
Third, you will have to cover the rubber part at the bottom of the shoes with masking tape to cover all the rubber on the bottom of you shoes.
Step 4:
Next,you will put some drops of black, dark blue,purple,red,white,pink,light blue paint on your paper plates.
Step 5:
Next,it looks really nice if you mix purple and dark blue together.
Step 6:
Then start painting the first shoe with dark blue at the top of your shoe where your toe is.
Step 7:
Then start adding black around the dark blue part of you shoe.
Step 8:
Then on the side of your shoe use the purple and light blue mix and put the paint on the lift side and right side towards the top of your shoe that is already painted and keep going with the paint towards the angle.
Step 9:
Then paint the back of your shoe red and dark blue together but you want to see the red in it so mix it for 10 seconds.
Step 10:
The after you paint your whole shoe and let your shoe dry. You start sponging on some lighter colours on the sides and you can use white ,light blue and pink.
Step 11:
Then put some white paint on your tooth brush.
Step 12:
Then flick the tooth brush with the white paint on the shoe to make small stars and you can do this by pulling the bristles back and letting the bristles go.
Step 13:
Then if you mix some of the stars together and then it looks like a cloud.
Step 14:
Then its time for bigger stars. You can do the big stars with a fine tip paint brush and most of the stars have to be like crosses or diamonds.
Step 15:
Next pull off the tape.
Step 16:
Then let your shoe dry and then put your laces back on the shoe.
Step 17:
Then do your other shoe. It doesn't have to be identical.
Step 18:
Now you're done. Have fun with your galaxy shoes.
