Introduction: How to Make Emergency Zip Tie Snow Chains
Are you stuck?
Are you constantly spinning your wheels?
Are you lacking the tools necessary to move forward with your life?
Do you know where you want to be, but don't know how to get there?
I was on the same road, but I found my motivation in zip ties.
Yes, you heard me correctly folks...zip ties.
I'm going to show you how to become unstuck and move forward over any obstacle, building momentum to reach your destination.
Step 1: Preparing the Build
Materials
- 36" zip ties
- 12" zip ties
- Scissors
- 6"+ of snow or ice
I had 24" zip ties on hand for the build, which was about 6" too short for my winter tires (225-65-17's), so I used two 24" zip ties daisy chained for the demo
Planning
You'll need to determine the number of "chains" that will you need for the situation and that will fit on your vehicles tires. My tires have six openings in the rim, so I made six "chains". The more chains you make, the more grip you will have, but I found six to be sufficient for the demo.
The long zip ties are the "chain" or base of the build, and the smaller zip ties are used for grip.
For my build this equaled six long zip ties in total, with six smaller zip ties per long zip tie, equaling 36 small zip ties in total.
Step 2: Assembling the Snow Chains
Building a chain
- Start by wrapping a smaller zip tie 6-8" from the head of a longer zip tie (the chain)
- Tighten as much as possible to prevent slippage
- Add a second smaller zip tie 1" down from the first small tightened zip tie
- Continue adding smaller zip ties in the same configuration until you've added six smaller zip ties to the chain
- Trim the smaller zip ties down to about a 1/4"
Loop through these instructions until you have the number of chains you need for your vehicle.
Step 3: Attaching the Chains to Your Tires
Tips for attaching:
- Turn your wheel all the way left, then right for easier access to the backside of the tire
- It's easier to thread through the rim and bring back around the outside of the tire than the opposite way
- Be careful of the tire stem. The chains will shift with the rotation of the tire, so be sure to put the chain towards the end of the opening where it will naturally get pushed
Steps
- Insert your chain through an opening in the rim, head first, pulling the head around the outside of the tire back to the front
- Connect the zip tie, tightening while keeping the smaller zips (the grip) on the tread of the tire
- Tighten fully
- Do this for the rest of your chains/openings on the rim
Step 4: Driving
- The chains will stay on your tire when driving through snow/ice. If you drive across stretches of pavement, the chains will likely breakdown and fall off
- Start out slow; don't spin your tires
- Remember that these are a temporary solution for traction
Have fun & good luck!
