Introduction: How to Make a Full Auto Airsoft Minigun [Halo Inspired Mobile Turret]
This is a type of cloud airsoft gun - named so because of how the pellets are blown around the reservoir before being fired out the barrel. Since there is nothing mechanical to get in the way of the workings of this gun the rate of fire is extremely high, an estimated 50 rounds per second. It would make a great airsoft turret to be mounted on the defensive wall of a home base.
The price of materials is just over $50 assuming the builder already has PVC primer and cement.
Parts List:
4' of 2" pressure rated sch40 PVC
4' of 1.25" pressure rated sch40 PVC
2" end caps x2
2" 90 degree elbow
2" 90 degree street elbow
1.25" end caps x3
1.25" couplings x2
1.25"x0.5" threaded reducer
0.5" threaded plug
6mm ID x 3' aluminum tube
Rubber tire valve
Air compressor blower valve w/ threaded ends
Close brass pipe nipple - to fit blower valve
Hose fittings - to fit blower valve - x2
1' air compressor hose - matched to hose fittings
Hose straps - for compressor hose - x2
Large hose straps
1" foam pipe insulation - or a wood block fitted for chamber support
Parts List:
2" end caps x2
2" 90 degree elbow
1.25" end caps x3
1.25" couplings x2
0.5" threaded plug
Rubber tire valve
Large hose straps
