How to Make a PCB at Home
Introduction: How to Make a PCB at Home
About: I like to make projects related to Electronics, Microcontrollers and Robotics.
Learn How to Make a Printed Circuit Board at home using the Iron & Laser Printer method and Ferric Chloride Etchant.
Don't forget to Subscribe for more projects: YouTube
Teacher Notes
Step 1: Parts & Materials
  • Copper Clad PCB - AliExpress
  • Ferric Chloride Etching Solution
  • PCB Drill + Bits - AliExpress
  • Sandpaper
  • Paper Cutter
  • Permanent Marker
  • Laser Printer
Step 2: Export Settings
Once you have finished designing the board layout of your circuit in Eagle, go to Layer Settings and select Hide Layers.
Next, select only the following layers for a bottom layer only PCB:
  • 16 - Bottom
  • 17 - Pads
  • 18 - Vias
  • 20 - Dimension
  • 45 - Holes
Then go to File>Print. Set the Printer to Microsoft Print to PDF.
Ensure that the following settings are also selected: Black and Caption.
Click OK and Save the file in the destination folder of your choice.
Step 3: Printer Settings
Print out the PDF file using a Laser Cutter on a sheet of Glossy Photo paper.
Ensure that the print scale is 1.0
Do not change any other printer settings.
Step 4: Cut the Image
Cut the PCB image to size using a paper cutter and scale
Step 5: Cut the PCB
Mark the dimensions of the image on to the PCB using a permanent marker. Then use a paper cutter and scale to cut the PCB to the correct size.
Step 6: Iron the PCB
Sand the PCB using a fine grit of sandpaper and some water.
Place the image directly upon the copper side of the PCB and iron it for approximately 10 minutes.
By doing so the laser printed ink will get transferred from the photo paper to the surface of the PCB.
Remove the excess paper with some water so that you are only left with the stained PCB.
Step 7: Etch the PCB
I made a solution of Ferric Chloride and Water. When we mix these two, an exothermal reaction takes place and hence we must mix the solution preferably in a plastic or glass container. Do not mix the solution in a metal container.
Shake the container for approximately 10 minutes. The acidic solution will slowly etch the unexposed copper. You can speed up the process by adding more ferric chloride.
Step 8: Drill Holes
I used an electric drill to drill holes for the components. You can also use a manual PCB drill to do so.
I also used a larger sized drill bit to drill holes for the mounting standoffs.
Step 9: Support These Projects
Some of the circuits I have made using this PCB fabrication method.
YouTube: Electro Guruji
Instagram: @electroguruji
Facebook: Electro Guruji
Instructables: ElectroGuruji
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Arduino Contest 2020
    3 Discussions
    ElectroGuruji
    ElectroGuruji
    Tip 1 year ago on Step 7
    You can use Washing Soda / Baking Soda to neutralize the etchant before disposal.
    ElectroGuruji
    ElectroGuruji
    Tip 1 year ago on Step 8
    I use a hammer and tiny nail to create small depressions before making holes with the electric drill. This improves the alignment accuracy of the holes and in most cases prevents the drill bit from moving about.
    audreyobscura
    audreyobscura
    1 year ago
    Thanks for sharing your etching tips!
