Introduction: How to Make a "Run Through the Sprinkler" Sprinkler
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
Step 7:
Step 8:
Now use the cement to glue the slip end of the female hose adapter to the end of the 5 inch piece.
Step 9:
Now use the clear cement to create a square of PVC pipe, with the 4 long sides and the 4 - 90 degree corners.
Step 10:
Now come that part that I messed up bad on. I drilled too many of too large of holes on each side of the square. Too many holes mean not enough pressure, so no water squirting out or the pipe. So this time I drilled 10 – 3/32 inch holes on each side. I had each hole slanting in a different direction than the hole beside it.
Step 11:
Then I hooked the hose up to it and turned on the water. This is the result. Enjoy!
