Introduction: How to Make the Awesomest Coke Jelly!
In this instructable I will show you how to make edible any drink that you like: Coke, Pepsi, Sprite, Fanta and more.
Step 1:
It's pretty simple. Pour into a saucepan of 150 ml of water and add 30 grams of gelatin. I use Dr. Oetker Gelatin, although you can use any, the main thing that it should be flavorless
Step 2:
Mix well and leave the mixture for 10-15 minutes to gelatin swollen.
Step 3:
Prepare a few plastic cups and your favorite drinks. For the test I use the Coke, Pepsi, Sprite, Fanta and Laimon Fresh.
Fill the cups with drinks. I poured into each of about 150 ml. Wait 5-10 minutes to let the gas out.
Step 4:
Then put the saucepan with the gelatin on low heat and stirring constantly bring to a liquid state. It will take 2-3 minutes.
The instruction says that the maximum heating temperature of gelatin is 60 degrees. Boiling is not allowed!
Step 5:
After the gelatin is completely dissolved, it should be immediately pour into the beverage and mix well.
Step 6:
Next, place the cups in the fridge. The freezing process takes 2-3 hours.
I think it is not worth mentioning that the cups can not be put in the freezer, otherwise you will get a piece of ice :)
Step 7:
After 3 hours all drinks turned into a jelly mass.
Step 8: ​It Looks Cool!
The taste is even better than caviar from Pepsi.
Step 9:
If you liked this project, don't forget to add to your favorites and share on social networks.
And please subscribe to my Youtube channel (in English):
https://www.youtube.com/channel/UCFdutCpuXNMkZMGP6FtrD-Q
If you haven't seen my previous project, be sure to check it out!
