Introduction: How to Mount Seat Post Bike Lights to a Pannier Rack
The problem with pannier racks is that they can block your rear light on your seat post. A solution is to mount it to the rack instead. With the light closer to the back of the bike, you might find it safer because drivers can see you sooner. In this Instructable, I will show you how to mount a 2W Cygo‑Lite Hot Shot bike light onto the rack.
Step 1: Materials
- 4" long PVC pipe
- 3" x 6" Plastic board
- Cable ties
- Epoxy putty or hot glue
- Rear bike light of your choice
- Rear reflector of your choice
- Duct tape
Step 2: Drill the Plastic Board
Drill holes for the cable ties and epoxy putty.
Step 3: Drill PVC Pipe
Drill holes for the cable ties (not shown) and epoxy putty.
Step 4: Glue the Pipe to the Plastic Board
When using the epoxy putty, make sure it flows through the holes on the plastic board and pipe for better strength.
Step 5: Cable Tie the Pipe to the Board
Time will tell how long it will last. If the epoxy does come off, the cable tie will keep your lights from falling off.
Step 6: Attach Bike Light to Adapter
If the pipe is too small, you can wrap the pipe with duct tape or rubber strips.
Step 7: Cable Tie the Adapter to Your Rack Mount
Outside Contest
Summer Fun Contest
Before and After Contest
