Introduction: How to Set a Keyboard Shortcut for Anything in Windows.
Too many things on your desktop? Have a file that before you reach, you have to traverse at least 50 folders? Open up your files faster? If one of these instances is your problem, then this will be a great deal of help to you: Keyboard shortcuts.
Yes, and this tutorial will teach you to configure a shortcut for any file/.program you use often. :)
Step 1: Do It the Hard Way First
Locate the file you want to put a shortcut on.
Don't worry, this will be the last time you'll be looking for it the hard way.
Step 2: Creating the Shortcut
Now, you right-click the file and select "Create shortcut".
Step 3: Creating the Shortcut, Part 2
Now, right-click the newly-created shortcut and click on "Properties".
Step 4: Creating the Shortcut, Part 3
Now, under the 'Shortcut' tab, click on the textbox opposite "Shortcut key:" In that textbox, press the buttons that you want to use as shortcut keys, such as "Ctrl + Alt + Shift + F" or something. Don't forget to use a shortcut that you can actually remember, like, perhaps, the first letter of the file. Then press "OK".
Step 5: Extra Advice
As an extra advice, if you can't remember all your shortcuts, put them all in a txt file or something... Yes, one that's linked to a shortcut key. Like Ctrl + Shift + Alt + N (for 'N' otepad). Now you have a shortcut for your shortcuts! :)
...shortception...
