Introduction: How to Turn an Old Flat Screen Into a LightBox for Free
This is the video I made for YouTube, it has all of the step, directions, and information. If you want, just watch the video. But make sure to vote for me in the leftovers contest and share with your friends.
Here is a direct link if you have any issues https://youtu.be/OW9jvl4QeEk
Step 1: Parts and Tools
Parts Needed;
All you need is one flat screen monitor, that's it!
Tools;
This can vary based on your screen but in general all you need is a phillips screwdriver.and your hands
Optional
Flat Head screwdriver
needle nose plyers
Its as easy as 1 2 3!
1. Disassemble
2. Remove LCD
3. Reassemble
Feel free to refer to the video at any point if you have any questions as it goes into deeper detail, you can ask any other questions in the comments below.
Do this at YOUR OWN RISK! On the small chance that any injury to yourself, others, or property may occur I will not be responsible for.
Step 2: Step 1 Disassembly
This step is the one that will vary most between brands and models but in general there is 2 steps.
First you will need to remove any screws that the screen might have, check under labels, and if a sticker says "Void if damaged or Removed" then remove it, it is either covering a screw or joint, also check under any rubber pads that may be there.
Part 2 Most modern monitors are held together with snaps or clips, so to separate these just gently lift up the bezel around the monitor, or use a flathead screwdriver on the joint around the panel, but this WILL cause minor to moderate damage to the plastic frame.
Step 3: Step 3 Remove the LCD Pannel
This is one of the most complicated parts, but it is not that hard. To do this you will need to remove the whole LCD and backlight assembly.
At this point you will need to remove the wires powering the backlight from the power supply board so that you can remove the screen and backlight assembly. You will also need to and remove any connecting cables to the main circuit board to the video circuitry by any means necessary, but usually there is some clips on the edge of the connector.
Next you must remove the metal frame that holds the assembly together. To do this you will need to take out any screws that may be arround the perimeter, then you will need to pop apart any snaps, and fold back any tabs that may be holding the frame in place.
Now you will need to remove the LCD. Take off the metal frame BUT be careful, there will be several thin plastic sheets inside that need to stay in order, but it shouldn't be too hard.
Now remove the LCD by folding it back around the edge with the flexible plastic circuitry, and remove the circuit board by removing any screws then pulling it off any tape\adhesive. and remove any connecting cables to the main circuit board by any means necessary, but usually there is some clips on the edge of the connector
Now you need to put back the metal frame, just put it back on and replace any screws\bent metal, and make sure the clips are back in place.
Before you go any further make sure that the wires connecting the backlight to the power supply are reconnected,
Step 4: Step 3 Reassemble the Frame
Ok now it is time to put it all back together. It is easy enough, just put the assembly back in the plastic shell, clip it together, put back any screws, and power it back up and see if it works!
Its that easy! And now you took an old piece of trash and turned it into a quality LightBox for all of your sketching and other various needs.
Please mark as one of your favorites and vote for me on the Leftovers contest
