Introduction: How-to: Wooden Badge With Safety Pin
Instruction. How-to make wooden badge with safety pin.
Step 1: Cut and Engrave
Cut and engrave badge using laser mashine.
Material: Birch plywood.
Red line - cut. Black line - engrave.
Information for inversion engraving
At first I put a dark stain on birch plywood, then varnish, dry, grind.
Or, you can just paint wooden blank.
Objective: Remove the top thin layer of paint from wooden blank and not burn wood.
Parameters for 40 watt laser machine:
- Speed - 300 mm / sec
- Maximum power - 13%
- Interval - 0.1 mm
You may need to experiment with parameters.
After a quick and low-power engraving almost no soot. Soot from the cutted edges of the product can be easily removed with a damp sponge soaked in normal water.
Effect of inversion engraving is stunning.
In this way, we are doing many projects.
Step 2: Safety Pin
Insert safety pin into holes of base.
Step 3: Glue
Apply glue to the base.
Step 4: Press
Join badge on the base.
Press down.
Allow the glue to dry.
Step 5: Enjoy!
It's ready.
Enjoy!
Step 6: Video
Watch video about making of wooden badge.
Step 7: Files
Download files: AI, EPS, PDF, DXF, CDR.
More projects for laser cutting: cartonus.com
