Introduction: How to Cook Perfect Rice - (4 Techniques)
Rice is a staple food in many parts of the world. Here I would like to demonstrate how you can make perfect rice.
Here I have demonstrated techniques of cooking rice:
- Pressure cooking white rice
- Pan
- Microwave
- Pressure cooking Matta Rice (Red parboiled rice)
The main problem faced while cooking rice is that:
- It will be either too watery, which means is was undercooked.
- It will be overcooked with the grains of rice too soft and clumped together.
- Use too much water to rice ratio and the rice will be mushy, too little water and the rice will be too dry and grains will be more chewy.
So here I will show you how to overcome all these and get good fluffy rice with separated grains
Step 1: White Rice in Pressure Cooker (1)
1 cup of rice is more than enough for an adult.
Ingredients:
Basmati Rice - 1 cup
Water - 1.5 cups to 2 cups
Optional: Cumin seeds - 1 Tsp, Cardamom - 5, Cinnamon stick - 1/2 inch, Cloves - 4
The ratio of rice : water varies with the kind of rice used and the nature of the dish.
Take basmati rice in a bowl , rinse it well then add water and soak it for atleast 30-45mins. Drain water.
Note: If you are soaking for just 15-20 mins then add 2 cups of water.If you are soaking for 30 mins and more add 1.5 cups.
Step 2: White Rice in Pressure Cooker (2)
Heat oil and saute the cumin seeds, cloves, cardamom and cinnamon stick.
Add rice and saute for 2 minutes in low flame. If you do not want the spices you can start sauting with the rice itself.
Step 3: White Rice in Pressure Cooker (3)
Add water. Pressure cook for 3-4 whistles.
For the first whistle cook in medium flame. Then cook for other whistles in low flame.
Switch off. Let the pressure completely release by itself. Open after 10-15 miutes.
Fluff the rice with fork.
Step 4: Microwave (1)
Ingredients:
Rice - 1 cup
Take rice in a bowl , rinse it well then add water and soak it for at-least 30-45 mins. Drain water.
Add enough water so that it covers the rice by 1″. Put your clean finger in the pot so that the tip of your finger touches the top of the rice (don’t go all the way to the bottom – we are measuring from top of rice.)
Step 5: Microwave (2)
Put the lid on. The rice cooker has air vents. his allows the steam to escape during cooking, which is good.
Microwave for 9 minutes on high. Let it sit for 3 minutes undisturbed to finish cooking. Then it’s done.Fluff the rice with fork.
That's it your rice is ready in no time.
Note: Use lids which has air vents
Step 6: Pan Cooking of Rice (1)
Here I will be showing how to make perfect rice using a pan. I have made a vegetable Pulao.
If you want plain rice just skip the spices and the vegetables.
Vegetable Pulao:
Basmati Rice - 1 cup (soaked in water for 1/2 hr)
Cumin seeds - 1 Tsp
Onions - 1/4 cup (cut length wise)
Greenchillies - 3 nos (cut length wise)
Cinnamon - 1/2 inch stick
Cloves - 3
Ginger - 1/2 inch
Garlic - 2
Coconut milk - 1 cup
Turmeric Powder - 1/4 Tsp (Optional)
Ghee
Salt - As reqd
Carrot - 1/4 cup
Beans - 1/4 cup
- Take rice in a bowl , rinse it well then add water and soak it for at-least 30-45 mins. Drain water.
Step 7: Pan Cooking of Rice (2)
Heat ghee in a non-stick sauce pan. Saute garlic, ginger, cloves, cumin seeds, cardamom and cinnamon stick.
Saute onions and when done add the vegetables. saute for 5 minutes till cooked.
Drain off the water from the rice and add it to the sauteed onions. Saute for a few minutes.
Step 8: Pan Cooking of Rice (3)
Add 1 cup of coconut milk and 1 cup of water and salt. Boil over medium heat.
When it starts to boil, close the pan and simmer for 10 minutes.
Cook, till it`s done.
Note: Keep checking the water content in between.
Step 9: Matta Rice/Brown Rice Cooking (1)
Matta rice is a local variety of rice in kerala. So this is how we cook Matta rice at home. You can cook brown rice this way too.
Ingredients:
1.5 cups Palakkadan Matta rice
12 cups water
Take the measured rice in the pressure cooker and wash it,rubbing the grains,until the water turns clear,about 4-5 times.
Step 10: Matta Rice/Brown Rice Cooking (2)
Add the 12 cups of water and keep the cooker on the stove.
Turn on the heat to low,cover the cooker and wait for the steam.
It will take anywhere between 5-6 minutes. Place the weight and cook the rice on low heat for 1 whistle.
Turn off the heat and let pressure go down on it's own.
Open and use as needed.
