Introduction: How to Make an Arduino Driven Piezo LOUD
- astable multivibrator as suggested by some piezo MFG..
- Arduino charge pump to boost the voltage (cool idea though)
- Arduino voltage booster (might be totally useful to another project though!)
I spent more hours than I will admit. Go to the dollar store and purchase their Intruder Alert noise maker and your'll find... an Auto Transformer and a 'black blob' of circuitry. The black blob is a pulsing square wave that the Arduino can produce.
The tranformer works well. If anyone can explain the phyisics behind its operation, pleas chime in! thanks.
The auto-transformer has three leads and you can measure the resistance across the leads to determine which is which. Here is the transformer that I measured: Pin1-2 154ohm and Pin 2-3 8ohm Pins 1-3 is ~161ohm. Also ozitronics posted some data (see picture) on his 'autotransformer' with similar resistance and 91mH/2.1mH inductance. If anyone can find similar transformers on Mouser I'd be interested in seeing it. thanks!
Credits: I stole the pictures/knowledge/ and content from the following places:
- How to harvest a piezo.(just a picture)
- this fellow has a couple circuits using 555 timers to produce a square wave using an auto transformer. PDF version
- Jack Lopez provided this nice schematic of the dollar store with 'black blob' circuit
xxx
Step 1: How to Drive a Piezo With an Arduino
Look up the piezo buzzer's resonant frequency. This one has a peak frequency of 2600 HZ shown on the cut sheet. It actually has two peak frequencies but I just chose one. The cut sheet selects the point in the middle of the two frequencies.
Next calculate the square wave you need to make on the Arduino. 1 second / 2600 = 385us (micro seconds).
The square wave is positive for half the time and neutral for half the time or 385/2 = 192us
You may use other frequencies but this is one of the loudest frequencies based on the mfg literature.
Arduino Code:
int piezoPin = 5;
void setup() {
pinMode(piezoPin, OUTPUT);
void loop() {
analogWrite(piezoPin, 255); //positive square wave
delayMicroseconds(192); //192uS
analogWrite(piezoPin, 0); //neutral square wave
