Introduction: How to Open Security Screws
About: You also have many workers: stonecutters, masons, carpenters, and people skilled in every kind of work in gold, silver, bronze and iron- beyond number. Now begin the work, and may the LORD be with you. 1Croni…
This instructable shows you how to open security screws.  Security screws are those stupid screws you see on products that the manufacture does not intend for you to open.  Ive seen these on hard drives and on a microwave.
There are two ways to open these without the special screwdriver, you can use a hammer and just bust the thing open (using brute force) or take a dremel and cut a slot or Phillips head into the screw.
Since we have evolved from the cavemen i will show you how a gentleman opens these.
You will need a dremel rotary tool and fiberglass reenforced cut off wheel.
appropriate PPE (glasses, ear protection, reflective belt)
Here is some cool information for screws
http://en.wikipedia.org/wiki/Screw
Step 1: Add a Slot Into the Top
This is too easy,
Take your dremel tool and carefully cut a slot in to the top of the screw.  You want to modify the screw head to accept the new tool as perfect as possible.  If you make the slot too wide then you risk shearing off the head and ruining the screw. If you make it too narrow then you risk injuring yourself when the tool slips.
With practice its possible to cut a Phillips head into the head of the screw.
Step 2: Remove Screw
Now you can remove the screw with ease.
If your doing a simple repair, such as replacing a fuse then just go to the hardware store and get some regular screws that match the thread and size.  If your busting into something then just toss the screws.
Hopefully this saves you a trip to the hardware store or having to special ordering security bits to open broken products.
