Introduction: Humanoid Robot Voiced Controlled With Arduino Mega, Raspberry Pi and 1Sheeld
Humanoid Robot is a robot shaped in the form of a human. A humanoid robot is used in many different fields such as education for young children, on field marketing for companies, research and development tool , entertainment and for tasks that are unsafe to be done with real people so humanoid robots are a tool for human luxury and safety.
Step 1: Get the Components
Motors:
19 smart servo Herkulex motor.
For interacting:
  1. webcam.
  2. 2 speakers.
  3. microphone.
1Sheeld is used for a remote control through the mobile phone.
Micro-controllers:
  1. Arduino Mega: it's used to control the servo motors for the movements of the robot.
  2. Raspberry Pi : it's used for the image processing and voice interaction.
You can find all the component you need in Robot shop.
Step 2: Design on Paper
To start you need to make your design on paper, calculate your dimensions and make torque analysis for each joint (motor) and how much load it'll be carrying.
Step 3: Software Design
Now you take your design to a 3D software designer (solid-works / inventor...) and turn it to a 3D model ready top be printed.
Step 4: 3D Printing
Choosing the printing material that is strong, cheap and light in the same time like plastic ABS.
Step 5: Coding
This is the Arduino code for controlling the robot using 1Sheeld
The Forward and Inverse Kinematics of our Robot is not discussed here but As an Alternative Solution we controlled each Servo with his own angle to get him to the Required Position.
you'll need the following libraries installed in your computer: Herkulex & 1Sheeld
#include <Wire.h><br>#include <Herkulex.h>
#include <OneSheeld.h>
#include <SoftwareSerial.h>  //Software Serial Port
#define RxD 52 //8 lenardo 52 mega
#define TxD 7
#define SLAVE_ADDRESS 0x04
#define DEBUG_ENABLED 1
int ReceivedData , Data;
int number = 0;
float y;
const int Pin1 = 22;
const int Pin2 = 23;
void setup()
    pinMode(Pin1, OUTPUT);
    pinMode(Pin2, OUTPUT);
    delay(1000);
    pinMode(RxD, INPUT);
    pinMode(TxD, OUTPUT);
    Serial.begin(115200);    // Open serial communications
    Serial.println("Begin");
    Herkulex.beginSerial3(115200); //open serial port 1
    Reboot();
    Herkulex.initialize(); //initialize motors
    // initialize i2c as slave
    Wire.begin(SLAVE_ADDRESS);
    // define callbacks for i2c communication
    Wire.onReceive(receiveData);
    Wire.onRequest(sendData);
    OneSheeld.begin();
    Herkulex.writeRegistryEEP(254,0x13,0x8E);
    delay(200);
    Herkulex.setLed(254,LED_PINK);
void loop()
  //Switch the Humanoid On/OFF
  /if(PushButton.isPressed())
    Reboot();
    Intial();
  else if(!PushButton.isPressed())
    Herkulex.torqueOFF(254);
    Herkulex.setLed(254,LED_GREEN2);
    Herkulex.end();
  if(ReceivedData == 2) //Giving a feedback about the detected Juics
       delay(10000);
       TextToSpeech.say("your Juics is ready");
       delay(100);
       ReceivedData = 255;
  if(ReceivedData == 3) //taking a Selfi
       Camera.setFlash(ON);
       Camera.rearCapture();
       delay(10000);
       Facebook.postLastPicture("Posted by @Neo Maelo");
       delay(100);
       ReceivedData = 255;
  //sensing the alarm ringtone of the mobile
  if(Mic.getValue() > 80)
    delay(10000);
    WakeUp();
    delay(1000);
    digitalWrite(Pin1, HIGH);
    digitalWrite(Pin2, LOW);
    delay(300);
    digitalWrite(Pin1, LOW);
  if(LightSensor.getValue() < 20 && LightSensor.getValue() > 0)
    sleep();
    delay(1000);
    digitalWrite(Pin2, HIGH);
    delay(300);
  //Accelometer Control
  if (GamePad.isRedPressed())
      y=AccelerometerSensor.getY();
      if ( y < 0) //Right Arm
        rightArm();
      else if (y > 0)
        leftArm();
  //Dance and music
   else if (GamePad.isGreenPressed())
    MusicPlayer.play();
    SimpleDance();
    MusicPlayer.pause();
  else if (GamePad.isBluePressed())
    Intial();
void rightArm()
  Herkulex.moveOneAngle(1, 130, 1000, LED_BLUE);
  Herkulex.moveOneAngle(4, -10, 1000, LED_BLUE);
  delay(1000);
void leftArm()
  Herkulex.moveOneAngle(1, 10, 1000, LED_BLUE);
  Herkulex.moveOneAngle(4, -130, 1000, LED_BLUE);
  delay(1000);
// callback for received data
void receiveData(int byteCount){
    while(Wire.available()) {
        Data = Wire.read();
        Serial.print("data received: ");
        Serial.println(Data);
        ReceivedData = Data;
// callback for sending data
void sendData(){
    number = ReceivedData;
    Wire.write(number);
void Reboot()
  Herkulex.reboot(0); //reboot first motor
  Herkulex.reboot(1); //reboot first motor
  Herkulex.reboot(2); //reboot first motor
  Herkulex.reboot(3); //reboot first motor
  Herkulex.reboot(4); //reboot first motor
  Herkulex.reboot(5); //reboot first motor
  Herkulex.reboot(6); //reboot first motor
  Herkulex.reboot(7); //reboot first motor
  Herkulex.reboot(8); //reboot first motor
  Herkulex.reboot(9); //reboot first motor
  Herkulex.reboot(10); //reboot first motor
  Herkulex.reboot(11); //reboot first motor
  Herkulex.reboot(12); //reboot first motor
  Herkulex.reboot(13); //reboot first motor
  Herkulex.reboot(14); //reboot first motor
  Herkulex.reboot(15); //reboot first motor
  Herkulex.reboot(16); //reboot first motor
  Herkulex.reboot(17); //reboot first motor
  Herkulex.reboot(18); //reboot first motor
  Herkulex.reboot(19); //reboot first motor
  delay(500);
void Intial()
Herkulex.moveOneAngle(0, 98.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(1, 10.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(2, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(3, -98.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(4, -10.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(5, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(6, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(7, -5.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(8, 2.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(9, 4.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(10, -2.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(11, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(12, 8.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(13, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(14, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(15, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(16, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(17, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(18, 0.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(19, 0.00, 1000, LED_BLUE);
delay(1200);
void Bye()
  for(int i=0; i <3; i++)
   Herkulex.moveOneAngle(0, 88, 700, LED_BLUE);
   Herkulex.moveOneAngle(1, 159, 700, LED_BLUE);
   Herkulex.moveOneAngle(2, 77, 700, LED_BLUE);
   Herkulex.moveOneAngle(3, -93, 700, LED_BLUE);
   Herkulex.moveOneAngle(4, -120, 700, LED_BLUE);
   Herkulex.moveOneAngle(5, -2, 700, LED_BLUE);
   delay(900);
   Herkulex.moveOneAngle(0, 76, 700, LED_GREEN);
   Herkulex.moveOneAngle(1, 92, 700, LED_GREEN);
   Herkulex.moveOneAngle(2, 3, 700, LED_GREEN);
   Herkulex.moveOneAngle(3, -76, 700, LED_GREEN);
   Herkulex.moveOneAngle(4, -140, 700, LED_GREEN);
   Herkulex.moveOneAngle(5, -83, 700, LED_GREEN);
   delay(900);
 void SimpleDance()
 Herkulex.moveOneAngle(3, -150, 1000, LED_BLUE);
 delay(950);
 Herkulex.moveOneAngle(3, -100, 1000, LED_BLUE);
 Herkulex.moveOneAngle(4, -60, 1000, LED_BLUE);
 Herkulex.moveOneAngle(1, 60, 1000, LED_BLUE);
 delay(950);
 Herkulex.moveOneAngle(0, 110, 1000, LED_PINK);
 Herkulex.moveOneAngle(1, 25, 1000, LED_PINK);
 Herkulex.moveOneAngle(3, -150, 1000, LED_PINK);
 Herkulex.moveOneAngle(4, -25, 1000, LED_PINK);
 delay(1000);
 Herkulex.moveOneAngle(7, -0.97, 1000, LED_BLUE);
 Herkulex.moveOneAngle(8, 2.60, 1000, LED_BLUE);
 Herkulex.moveOneAngle(9, 4.88, 1000, LED_BLUE);
 Herkulex.moveOneAngle(12, 1.63, 1000, LED_BLUE);
 Herkulex.moveOneAngle(14, -1.63, 1000, LED_BLUE);
 Herkulex.moveOneAngle(0, 150, 1000, LED_GREEN);
 Herkulex.moveOneAngle(3, -110, 1000, LED_BLUE);
 delay(1000);
 Herkulex.moveOneAngle(0, 110, 1000, LED_BLUE);
 Herkulex.moveOneAngle(3, -150, 1000, LED_GREEN);
 delay(1000);
 delay(1000);
 delay(1000);
 Herkulex.moveOneAngle(0, 160, 1000, LED_GREEN);
 Herkulex.moveOneAngle(3, -160, 1000, LED_GREEN);
 Herkulex.moveOneAngle(4, -70, 1000, LED_BLUE);
 Herkulex.moveOneAngle(1, 0, 1000, LED_BLUE);
 delay(1000);
 Herkulex.moveOneAngle(4, 0, 1000, LED_BLUE);
 delay(1000);
 Herkulex.moveOneAngle(0, 98.70, 900, LED_BLUE);
 Herkulex.moveOneAngle(1, 10.00, 900, LED_BLUE);
 Herkulex.moveOneAngle(3, -98.70, 900, LED_BLUE);
 Herkulex.moveOneAngle(4, -10.00, 900, LED_BLUE);
 delay(800);
 Herkulex.moveOneAngle(0, 160, 900, LED_GREEN);
 Herkulex.moveOneAngle(3, -160, 900, LED_GREEN);
 Herkulex.moveOneAngle(4, -70, 900, LED_BLUE);
 Herkulex.moveOneAngle(1, 0, 900, LED_BLUE);
 delay(900);
  Herkulex.moveOneAngle(0, 89.05, 1500, LED_BLUE);
  Herkulex.moveOneAngle(1, 116.67, 1500, LED_BLUE);
  Herkulex.moveOneAngle(3, -92.30, 1500, LED_BLUE);
  Herkulex.moveOneAngle(4, -149.83, 1500, LED_BLUE);
  Herkulex.moveOneAngle(6, 12.02, 1500, LED_BLUE);
  Herkulex.moveOneAngle(10, 1.63, 1500, LED_BLUE);
  Herkulex.moveOneAngle(11, 30.55, 1500, LED_BLUE);
  Herkulex.moveOneAngle(15, 20.47, 1500, LED_BLUE);
  delay(1500);
  Herkulex.moveOneAngle(6, -7.00, 1000, LED_BLUE);
  Herkulex.moveOneAngle(10, -8.60, 1000, LED_BLUE);
  Herkulex.moveOneAngle(11, 8.00, 1000, LED_BLUE);
  Herkulex.moveOneAngle(15, 8, 1000, LED_BLUE);
  delay(900);
  Herkulex.moveOneAngle(1, 144.95, 1500, LED_BLUE);
  Herkulex.moveOneAngle(4, -123.17, 1500, LED_BLUE);
  Herkulex.moveOneAngle(6, -22.42, 1500, LED_BLUE);
  Herkulex.moveOneAngle(10, -19.17, 1500, LED_BLUE);
  Herkulex.moveOneAngle(11, -5.85, 1500, LED_BLUE);
  Herkulex.moveOneAngle(15, -1.63, 1500, LED_BLUE);
  delay(1500);
  delay(1500);
  delay(1500);
  delay(900);
  delay(1500);
  delay(1500);
  Intial();
void sleep()
  Herkulex.moveOneAngle(0, 97.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(1, 9.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(2, -1.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(3, -97.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(4, -9.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(5, -1.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(6, 1.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(7, -37.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(8, -69.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(9, 43.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(10, 1.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(11, 1.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(12, 43.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(13, 69.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(14, -37.00, 2000, LED_BLUE);
Herkulex.moveOneAngle(15, 1.00, 2000, LED_BLUE);
void WakeUp()
Herkulex.moveOneAngle(6, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(7, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(8, 2.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(9, 4.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(10, -2.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(11, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(12, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(13, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(14, 0.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(15, 0.00, 1200, LED_BLUE);
delay(1000);
Herkulex.moveOneAngle(0, 160.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(1, 30.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(2, -1.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(3, -143.00, 1200, LED_BLUE);
Herkulex.moveOneAngle(4, -26.00, 1200, LED_BLUE);
delay(1200);
Herkulex.moveOneAngle(1, 90.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(2, -1.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(3, -159.00, 1000, LED_BLUE);
Herkulex.moveOneAngle(4, -64.00, 1000, LED_BLUE);
delay(1200);
Intial();
