IOT Based Water Level Controller Using NodeMCU ESP8266
Introduction: IOT Based Water Level Controller Using NodeMCU ESP8266
About: I am a professional blogger from India.
This is Instructable on how to create an IOT based water level controller.
Features of this project are:-
  • Real-time water level updates on the Android app.
  • Automatically turn ON the water pump when water reaches below a minimum level.
  • Automatically turn OFF water pump when water reaches above a maximum level.
  • Manual option to control the water pump at any water level.
Requirements:-
    1. NodeMCU ESP8266 development board
    2. HCSR04 ultrasonic sensor
    3. Breadboard
    4. Single channel relay board (to control water pump)
    5. LM7805 +5V voltage regulator IC.
    6. Battery (9V-12V).
    7. WiFi Router (to connect NodeMCU to internet)
    8. Firebase (to create a database)
    9. MIT app inventor 2 (to create Android application)
    So let's get started.
    Step 1: Setup Firebase and Get Secret Key
    We are going to use a real-time database by Google firebase. This real-time database will act as a midway broker between Nodemcu and Android device.
    • First of all, navigate to firebase site and log in using your google account.
    • Create a new real-time database.
    • Get real-database URL and secret key to access the database from the app. For a detailed tutorial, you can check out how to integrate firebase with MIT app inventor.
    Step 2: Create App Using MIT App Inventor 2
      We are going to use MIT app inventor 2 to create our Android app. Its very simple to use and easy to integrate win Google firebase.
      Just follow these steps:-
      • Download MIT app inventor project file (.aia file) attached below.
      • Then go to MIT app inventor >> projects >> import project (as shown in screenshot 1). Select the file from your computer and upload it.
      • Open project and navigate to Screen3 (as shown in screenshot 2).
      • After that, go to layout window, click on firebaseDB1 (located at bottom of the workspace), enter database URL and key. Also set ProjectBucket to S_HO_C_K (as shown in screenshot 3).
      • At last, click on the "build" button and save app file (.apk file) to your computer. Later transfer that file to your Android device.
      Step 3: Configure Arduino IDE for Nodemcu Esp8266
      • First of all, configure Arduino IDE for Nodemcu esp8266. I would recommend this step by step tutorial on NodeMCU basics by Armtronix. Thanks Armtronix for this helpful tutorial.
      • After that, add these two libraries (as shown in screenshot) :-
      1. Arduino Json
      2. Firebase Arduino
      Step 4: Upload Code With Some Necessary Changes
      You must do some necessary changes in code before uploading to Nodemcu.
      • Download attached file (.ino file) and open it with Arduino IDE.
      • At line 3, enter database URL without 'https://'.
      • At line 4, enter database secret key.
      • At line 5 and 6, don't forget to update WiFi SSID and Wifi password (to which you want to connect NodeMCU ESP8266).
      • Scroll down a little bit and update minimum water level, maximum water level, and margins according to the depth of your own water tank.
      After that, upload program to NodeMCU ESP8266.
      Step 5: Configure Hardware
      • Create a circuit as shown in the above figure. You can use either a 9V or 12V battery.
      • Put ultrasonic sensor at the top of the water tank.
      • Connect water pump using a relay board (optional during testing).
      Step 6: Magic Time!
      • Install the app (created in step 2) on your Android device.
      • Supply power to the setup.
      • Wait for NodeMCU to connect to the hotspot (you can use either router or portable hotspot).
      • All Done! Now you can control/monitor water level from anywhere in the world.
      IoT Challenge
      IoT Challenge
      Be the First to Share
        • Pocket-Sized Speed Challenge
        • Audio Challenge 2020
        • Maps Challenge
          Maps Challenge
        14 Discussions
        hoornhecht
        hoornhecht
        Question 4 weeks ago on Introduction
        hello sir,
        i love this project and i will aply it to my house.
        just jesterday i put all the compnets togeher and follow your guideline.
        but there is a chaange in the real time database conection.
        please can you help me?
        the esp can not log in the google fire base.
        for faster contact we can comunicate as well via watzapp +5219841642155
        sorry i'm totally new with aduino and maybe i need a bit special help :-)
        Rishi Rishi
        Rishi Rishi
        Answer 4 weeks ago
        Hi there,
        Glad you liked my project :)
        I'm not sure why esp not logging data to firebase. Are you getting firebase connection failed error in serial monitor?
        If yes, try this : https://m.youtube.com/watch?v=ZZ5JvSA-Ed8
        For more help, please send me personal message here on instructables. I would be happy to help you.
        Thanks
        hoornhecht
        hoornhecht
        Reply 4 weeks ago
        Hello,
        I found the problem! Now it works fine thanks
        Rishi Rishi
        Rishi Rishi
        Reply 4 weeks ago
        That's great!!!
        hoornhecht
        hoornhecht
        Reply 4 weeks ago
        Now I start modify for my case.
        Keep in contact
        patronsautomation
        patronsautomation
        3 months ago
        Sir.. please help me..
        In serial monitering shows.. Error connecting firebase
        patronsautomation
        patronsautomation
        Reply 2 months ago
        If you domt mind kindly givee uour whatsapp nbr.
        My number 9349290112
        patronsautomation
        patronsautomation
        Reply 2 months ago
        Sir,
        I connected with 7805 voltage regulator to sensor but still same things is showing... sensor have no problem that i connected in other project that is working.
        Everry thing ready.
        Triger for 10
        Duration calculated
        Assembing sonar
        Distance 0
        Water above desired level motor Off
        patronsautomation
        patronsautomation
        Reply 2 months ago
        Thanks for your response...
        Now fiebase connection problem solved that beacause of figerprint auth change... now it is connecting with firebase..
        But data level not changing it always show 4.
        Manual operation not working.. level of the tank also not showing..
        Level not changing with respect water level.
        15865996559733845374284292666402.jpg15865997278623000335862304673636.jpgScreenshot_20200411_154031.jpg
        joecam
        joecam
        1 year ago on Step 6
        Awesome! Thank you very much
        Rishi Rishi
        Rishi Rishi
        Reply 1 year ago
        Your Welcome!
        Daijoubu
        Daijoubu
        1 year ago
        Careful since the ESP uses 3.3V logic, the signal from that 5V powered ultrasonic sensor may need to be converted to TTL level.
