Industrial End Tables
6,173
117
12
Introduction: Industrial End Tables
About: I'm a designer at Instructables. I have a degree in fashion design and like to sew, get crafty, and attempt to use power tools.
I recently moved into an apartment with a relatively small bedroom, and couldn't find any small end tables I liked at all. Of course that means time to make some so they could be exactly what I wanted! I love the industrial rustic look that is oh so popular right now, and went with angle steel and redwood. These were relatively simple to make, but between sanding time and curing time they weren't as quick as I'd initially hoped. Still I'm quite happy with them and they fit well in my small space.
Supplies:
  • Wood of your choosing. I used one 12" board of rough cut redwood.
  • Angle steel. These are 18" high exactly so used one 6' 1.5" bar each.
  • Wood finish of your choice. I used this tung oil with a little tint.
  • 1" flat head wood screws.
Teacher Notes
Step 1: Cut Steel
First I cut the 6' steel into 4 equal pieces of around 18" each. Because I was using one length to its full extent, I was careful to mark and cut in the middle of the mark so as not to end up with uneven lengths due to loss from the blade width.
Once done, I ground down the sharp edges at either end.
Step 2: Drill Holes in Steel
Next, I marked and drilled the holes. This took a little more planning and testing of various shelf positions before making a decision. I also experimented with different screw lengths and positions so as not to have them intersect, and positioned the holes accordingly (I didn't use the screws pictured as they are tapered, but they were reference for length).
Once I knew where to drill, I marked on the inside of the angle, and punched each of my marks to give the drill press an easy start. Setting things up in the drill press took some doing, as you can see from the piece of wood I used as a spacer to give enough room for the drill to access where the holes needed to be. This set up ended up working quite well.
When finished, I deburred a little bit, and cleaned up my steel. That was it for metal work, then I moved on to the wood.
Step 3: Prepare Wood
I had decided on rough cut redwood because I wanted some texture, but in the end I probably should have gotten something else as the texture that really stood out was the saw marks. Ah well, it was cheaper :)
I cut three identically sized lengths per end table (these were 13"x12"), and sanded them down until the surface was to my liking.
Step 4: Oil Wood
The last step before assembly was to finish the wood. I wanted to use something that was more on the natural side. I chose this tung oil because it is billed as non-toxic with zero VOCs, but man it took MONTHS to cure. I think it took a full 6 months for the smell to totally dissipate. That said, I am quite happy with the quality and color of the finish. I also made a table top at the same time which was a more amber tone, and I really like how the tint came out on that piece. I was worried the tint might be muddy on the redwood, but I'm happy with the color on that tone as well.
I followed the directions on the bottle, and added as many coats as I could before it seemed as though the wood was totally saturated, then left them overnight, and applied a final single coat in the morning. After wiping off any excess, I leaned them each individually against the walls in my stairwell so all sides were exposed to the air.
If any woodworkers out there have other natural finishes you like that don't have much in the way of VOCs, I'd love to hear your suggestions!
Step 5: Assemble
Once I waited months for my zero VOC tung oil to cure and stop smelling quite so much (at least a month), it was finally time to assemble. The wood had warped a bit in the meantime, so that was the biggest challenge. I learned this the hard way by attaching all four legs to the top shelf piece, then adding the two underneath only to find a lot of huge gaps.
To manage this, I added all three shelves at once with only one screw per angle bar, with them all loose enough to have some wiggle room. From there I tightened bit by bit, in whatever way seemed to mitigate the irregularities the best. This was a lot of tightening, loosening, and swapping shelves, but in the end I managed to get the top shelves flush and the bottom shelves good enough.
Step 6: Done!
With that the end tables were done (save a few more months of off-gassing). If you make some, do share them in the comments!
Furniture Contest
Furniture Contest
Be the First to Share
    • Magnets Challenge
      Magnets Challenge
    • Snow Challenge
      Snow Challenge
    • Wearables Contest
      Wearables Contest
    12 Discussions
    celiosantos
    celiosantos
    9 days ago
    Hi, very good Instructable, nice industrial look, but regarding the so called zero VOC oil... if it is smelling for months, may the smell cause its some kind of organic resin that slowly volatilize ?
    BubbaGee
    BubbaGee
    15 days ago
    I have one suggestion for your project. I would either spray bedliner or some kind of rubber to the bottom of the legs to reduce the chance of damaging the floor. Even a 3D printed foot to add to the bottom of the foot would be nice.
    Natalina
    Natalina
    Reply 14 days ago
    Yes agreed. I was thinking about this and planning to either add felt/rubber cut outs, or just half some of those ready made felt circles. I'll add a step to address this when I get around to it. I've never used bedliner, think it would be easy to do a clean application on an edge like this?
    ChryssO
    ChryssO
    Question 16 days ago on Step 6
    One of my favorite looks. Tried a version of it for a stand for my massive printer, but mine's a bit wobbly because I needed it to be open in the front, and i didn't quite get the structure right for the stability, in the interest of saving materials. Doh.
    May i ask how much it cost you to make these? The cost of certain materials at Home Depot has gone through the roof here.
    Natalina
    Natalina
    Answer 15 days ago
    I bought the angle steel and redwood at a local store, but I think the price of the steel at least was similar to Home Depot. For wood and steel for both it was around $50.
    Bruceaulrich
    Bruceaulrich
    17 days ago
    These look great! I love the steel and wood look. Nice job!
    Natalina
    Natalina
    Reply 16 days ago
    Thanks!
    RobertN124
    RobertN124
    18 days ago
    Well done. Simple, practical and very nice looking.
    bekathwia
    bekathwia
    18 days ago
    They turned out so great! Awesome work and thanks for sharing your process.
    simon beveridge
    simon beveridge
    19 days ago on Step 6
    Too good. These came together simply and cheaply (my two favourite things). I only wish I'd thought of it myself. Infintitely customisable. I just needed to treat the 'legs' a bit more as the humidity here eats steel. I used a rattle can to lightly spray paint the metal pieces after they were cut and drilled.
    Natalina
    Natalina
    Reply 18 days ago
    Did you make some already? If so post an I Made It, I'd love to see them!
