Introduction: Install OpenHAB on Raspberry Pi
Install latest version of openHAB on Raspberry Pi and get the demo running. For many makers, the internet of things is all about home automation. openHAB is the leading open-source home automation hub.
I struggled with openHAB's installation instructions. Home Automation for Geeks' instructions helped me get an old version running (1.7). However, I wanted to install the latest stable version.
The instructions were verified with 1.8.3, but should work for any new stable version.
In general, raspbian and debian variants use packages enabling simple installation with apt-get. However, java is operating system independent and uses zip files for installation. openHAB has apt-get install, but it didn't work for me.
Notes:
- Replace text enclosed in spades with an actual value ♣replace-this♣
- Remove spaces around the colon (https : //)
- Setup Raspberry Pi (any model) running raspbian or DietPi
- I use a MacBook but any computer can be used. I think the only change if you are using a PC, is to use putty to login and open a terminal window.
- My openHab Raspberry Pi is using ♣ip-address♣ = 192.168.1.100
Step 1: Step-by-Step Install
Step-by-step instructions follow, or go to the next step and use an unattended install to do the steps below.
Open terminal window and ssh into Raspberry Pi
$ ssh pi@♣ip-address♣
Always update and upgrade
$ cd ~/. $ sudo apt-get update $ sudo apt-get upgrade
Install java and eclipse
Check if java and eclipse are installed. If installed, then you should see /usr/bin/java or /usr/bin/eclipse. If not installed, install them
$ which java $ sudo apt-get install oracle-java8-jdk -y $ which eclipse $ sudo apt-get install eclipse -y
Install Mosquito
Remove the spaces around the colons.
$ wget http : //repo.mosquitto.org/debian/mosquitto-repo.gpg.key $ sudo apt-key add mosquitto-repo.gpg.key $ rm mosquitto-repo.gpg.key $ cd /etc/apt/sources.list.d/ $ sudo wget http : //repo.mosquitto.org/debian/mosquitto-jessie.list $ sudo apt-get update $ sudo apt-get install mosquitto mosquitto-clients
Test Mosquito
$ mosquitto_sub -d -t hello/world
Open a second terminal and ssh in
$ ssh pi@♣ip-address♣ $ mosquitto_pub -d -t hello/world -m "Hello from terminal window 2!"
The message from window 2 should appear in the first window.
Logout and close second terminal window.
CTRL-c in the first terminal window
Make directories
$ ssh pi@♣ip-address♣ $ sudo mkdir /opt $ sudo mkdir /opt/openhab $ sudo chmod -R ugo+rw /opt/openhab
Get links to latest version of openHAB
On MacBook (or PC):
- open browser
- open text file
In browser, go to openHAB downloads page and copy the following links to text file:
- Runtime core
- Addons
- Demo setup
To copy a link on a MacBook, hold CTRL and click on link, then select Copy Link
Paste each link into text file. You will see something like this:
CTRL-Click on Download and Edit Link. Select the link, copy it and paste it to text file. You will see something like this:
https : //bintray.com/artifact/download/openhab/bin/distribution-1.8.3-runtime.zip
Remember to remove spaces around the colon.
As of 27MAY2016, the current openHab links for the stable release 1.8.3 are:
♣runtime-core♣ = ♣https : //bintray.com/artifact/download/openhab/bin/distribution-1.8.3-runtime.zip♣
♣addons♣ = ♣https : //bintray.com/artifact/download/openhab/bin/distribution-1.8.3-addons.zip♣
♣demo-setup♣ = ♣https : //bintray.com/artifact/download/openhab/bin/distribution-1.8.3-demo.zip♣
Download latest version of openHAB
Run the following commands using links and names from above
$ cd /opt/openhab $ sudo wget ♣runtime-core♣ $ ls ♣runtime-core-zip-file♣ $ sudo unzip ♣runtime-core-zip-file♣ $ sudo rm ♣runtime-core-zip-file♣ $ cd /opt/openhab/addons $ sudo wget ♣addons♣ $ ls ♣addons-zip-file♣ $ sudo unzip ♣addons-zip-file♣ $ sudo rm ♣addons-zip-file♣ $ cd .. $ sudo wget ♣demo-setup♣ $ ls ♣demo-setup-zip-file♣ $ sudo unzip ♣demo-setup-zip-file♣ $ sudo rm ♣demo-setup-zip-file♣ $ sudo chmod +x start.sh
Start openHAB running
$ cd /opt/openhab $ sudo ./start.sh
openHAB takes about 5 minutes to start
In the browser, open a new tab and go to (remove spaces around colon):
http : //♣ip-address♣:8080/openhab.app?sitemap=demo
And it should work!
However, openHAB should really start and run on boot.
Stop openHAB
CTRL-z to stop openHAB. I haven't figured out how to recover from stopping openHAB. The only way to get openHAB to work after stopping is to reboot.
Add username and password
$ sudo nano /opt/openhab/configurations/users.cfg
and add the following line, replacing names in spades with real values. Even though I am using diet-pi, I created a pi username.
user=password,user,role ♣username♣=♣password♣
Add MQTT binding
$ cd /opt/openhab/configurations $ sudo cp openhab_default.cfg openhab.cfg $ sudo nano openhab.cfg
CTRL-w to search for mqtt and uncomment the lines and edit to look like:
mqtt:broker.url=tcp://localhost:1883 mqtt:broker.clientId=openhab
Use localhost and not your ♣ip-address♣. DHCP might change the ip-address and localhost will keep up with these changes.
CTRL-o, ENTER, CTRL-x to write and exit nano editor
Start openHAB on boot
Unless running an old version of raspbian, don't use init.d. Diet-Pi and raspbian use systemd, which is is a linux init system to bootstrap user space and manage processes. To check if systemd is being used, enter the command:
$ ps -p 1 -o comm= systemd
Make system directory if it doesn't exist and create a start-up file
$ sudo mkdir /usr/lib/systemd/system $ sudo nano /usr/lib/systemd/system/openhab.service
And add
[Unit] Description=openHAB Home Automation Bus Documentation=http://www.openhab.org Wants=network-online.target After=network-online.target [Service] Type=simple GuessMainPID=yes User=pi ExecStart=/opt/openhab/start.sh ExecStop=kill -SIGINT $MAINPID Restart=on-failure WorkingDirectory=/opt/openhab [Install] WantedBy=multi-user.target
To save and exit: CTRL-o, ENTER, CTRL-x
Change owner recursively on openhab.
$ sudo chown -R pi:pi /opt/openhab
Reload systemd to make the daemon aware of the new configuration.
$ sudo systemctl --system daemon-reload $ cd /usr/lib/systemd/system $ sudo systemctl enable openhab.service $ sudo systemctl start openhab.service $ sudo reboot
Fix any issues in the logs. To see the log, enter the command:
$ sudo journalctl -f -u openhab.service
CTRL-c to stop
$ sudo reboot
And it works!
Step 2: Unattended Install of OpenHAB Demo
Make openHAB Demo Installation very easy by automating the previous step using a bash unattended install script. The script assumes a raspberry pi running raspbian or dietpi, which was setup using one of the embedded links.
I finished the script on github and
- tested the source on dietpi
- tested unattended install script on dietpi
- ran one time
- ran multiple times, with CTRL-c interrupts
- tested unattended install script on raspbian
The script assumes the username = pi, and the password = raspberry, and the script is trying to install openHAB 1.8.3. If these aren't correct, then edit the file accordingly.
Open terminal window on a MacBook or PC and run the following commands:
$ ssh pi@♣ip-address♣ $ sudo wget "https://raw.githubusercontent.com/dumbo25/install-openhab-demo/master/openhab_uai.sh" $ sudo chmod o+x openhab_uai.sh $ sudo bash openhab_uai.sh $ sudo reboot
The script takes about ten minutes to run onraspbian.
Be sure to reboot the Raspberry Pi and wait 5 minutes until openhab starts
And it should work!
Once it works, be sure to change the hostname and password.
