Introduction: Installation Guide for Magneti Marelli Module on Fiat Freemont 170 CV AWD
For installation remove the engine cover and search the connector to disconnect.
Unpack the cables.
Step 1: Prepare the Module
Connect the main connector to the additional module.
To prevent any water infiltration isolate the connector. Place the module on the left front wheel arches.
Step 2: Search the Original Connector
Identified the connector using a screwdriver and disconnect using the module connectors additional equivalent practicing bypass
Step 3: Connect Module
The module connector has two additional tabs that obstruct the correct insertion of the connector.
Using a cutter to clear them. insert the connectors and work is completed.
Step 4: Reassemble
reassemble the engine cover.
Installation time 30 min.
