Introduction: IoT GitHub Frame
IoT GitHub Frame is a photo frame with built-in device based on the ESP32 module. This project will help you track the popularity of selected GitHub repository. You will be able to follow live the number of stargazers, watchers and forks. The frame can also display the number of daily stargazers. Simple configuration, automatic updates via HTTPS OTA, stability of operation. These are just some of the advantages of this project. The frame will look great on the wall in your home or office.
Check out the GitHub page for more details.
Step 1: What You Will Need
Necessary parts
  1. ESP-32 WROOM DevKit 1.0 – 1 pc.
  2. 4-digit display TM1637 0.56" - white color– 1 pc.
  3. 4-digit display TM1637 0.36" – 1 pc.
  4. 4 Pin F/F 200mm Cable – 4 pcs.
  5. JST 1.25 2-Pin Male - Female Connector – 2 pcs.
  6. Micro JST 1.25 2-Pin Male - Female Connector – 2 pcs.
  7. Universal PCB stripboard 50x70mm PI-01 – 1 pc.
  8. Carbon Film Resistor – 220 ohm – 5 pcs.
  9. Carbon Film Resistor – 2,2k ohm – 3 pcs.
  10. Breadboard Jumpers - 1 set
  11. Pin Header Right Angle Male – 1 pcs.
  12. LED Diode 5mm RGB with common anode – 1 pc.
  13. LED Diode 3mm white – 3 pcs.
  14. Round Push Button - momentary – 10mm – 2 pcs.
  15. ON-OFF switch – 1 pc.Cable USB A – USB micro – 1 pc.
  16. Phone charger with usb output 5V – 1 pc.
  17. Heat Shrink Tubing - 1 pc.
  18. IKEA RIBBA photo frame – 21x30cm ( it must be thick ) – 1 pc.
  19. Self-adhesive paper for the printer – 1 pc.
Tools
  1. Soldering iron
  2. Solder
  3. Drill or screwdriver
  4. Drills: 7, 10, 13
  5. Hot glue gun
  6. Knife
  7. Printer
Step 2: Soldering
Solder electronic components to the PCB as in the picture. Soldering start from the lowest elements. For connecting displays and LEDs use angled connectors. After finishing soldering, your board should look similar like on photo.
Step 3: Drilling Holes and Gluing
In the printouts folder you will find print templates that will help you drill holes:
Print them and then tape back template to the back of the frame and side template on the right edge of the frame. Use the appropriate drills to drill the holes. Cut the holes for the displays and the button with a knife. Then insert the displays and diodes in the holes using hot glue.
Step 4: Template Customization
In this step you need to adapt the graphics to your repository. To do this, edit the main PSD file and then print it on a regular A4 sheet. You can use the free online editor Photopea. If you want to, you can also print a label with the description of the side buttons. The self-adhesive paper works best for this.
Step 5: Uploading Program
Now you have to program ESP32 module. Download the latest Arduino IDE and the necessary libraries. Clone repository. Connect the ESP32 via the USB cable to the computer and upload the code.
Step 6: Configuration
After upload firmware, unplug and plug again USB cable to your device. Status led should glow in red. After few seconds should change color to blue. It means that device is in AP mode. Using a computer or phone scan nearby networks and find GITHUB-FRAME ssid. Once you connect to the selected access point you will be automatically redirected to the configuration page. Here you enter the name and password for the network with which your frame will connect. Save credentials and reset ESP.
If everything has been done correctly, the status LED should be green and the display should show SEt rEPO IP192.168.xxx.xxx. This means that we must now select the repository. Go to computer or phone and connect to the same WiFi network as ESP. Then in browser url placeholder type ip address of your ESP. You will be redirected to the page with the configuration of the repository. In example: For repository url: https://github.com/DivanteLtd/vue-storefront
Fill form fields and click save configuration.
That’s all :)
Now you can follow the popularity of the selected repository.
Have a nice building !
