Introduction: Jump Lift, a Knex Ball Machine Lift
Hello knexers!
This is the last of 4 new lifts all first seen in my knex ball machine Paradox.
It's a small lift that was used to lift the balls from the low white floor to the high white floor, but you can use it like you want.
You can make this lift stronger by adding more than 1 rubber band, and it also depends on wich rubber band you're using.
That's the reason why I didn't make an exit for this lift: The height and distance of the balls will be different for everyone.
If you build this lift, read every image note! It will help you a lot!
If you have any problems or questions, feel free to comment or PM me.
I hope you like it and have fun with building!
~Sandroknexmaster~
video:
~Sandroknexmaster~
video:
Step 1: Piece Count
If you want you can count the pieces before you start building.
Here is a list with all pieces included in this lift, named by their original color:
RODS:
Green: 24
White: 7
Blue: 25
Yellow: 8
Red: 2
Total rods: 66
CONNECTORS:
Dark-grey: 2
Light-grey: 3
Orange: 6
Red: 4
Green: 1
Yellow: 7
White: 2
Purple: 28
Blue: 4
Total connectors: 57
OTHER:
Blue spacer: 7
Silver spacer: 9
Tan clip: 9
Y-clip: 4
Small blue gear: 2
Medium red gear: 2
Motor: 1
Rubber band: 1 (or more)
Total other: 35
Grand Total: 158
RODS:
Green: 24
White: 7
Blue: 25
Yellow: 8
Red: 2
Total rods: 66
CONNECTORS:
Dark-grey: 2
Light-grey: 3
Orange: 6
Red: 4
Green: 1
Yellow: 7
White: 2
Purple: 28
Blue: 4
OTHER:
Blue spacer: 7
Silver spacer: 9
Tan clip: 9
Y-clip: 4
Small blue gear: 2
Medium red gear: 2
Motor: 1
Total other: 35
Grand Total: 158
Step 2: Frame
This is the base structure for the lift.
Step 3: Motor Section
This part contains the motor and most of the gears.
Step 4: Entrance
The Entrance. The balls will wait on this track before they will jump in the air.
Step 5: Shooter
This little arm will launch the balls in the air.
Step 6: Axle
This is the Axle. At the end, we will also add the rubber band(s).
Step 7: Finished!
Yay! You just finished building your own Jump Lift!
Always slide the switch of the motor to the left.
You can always send me a picture when you've built this lift so I can add it to this step.
Thanks for watching / building!
~Sandroknexmaster~
