PIWOOLET (Pi.WOOd.tabLET): Just an Other PI Tablet
11,574
111
11
Introduction: PIWOOLET (Pi.WOOd.tabLET): Just an Other PI Tablet
About: My name is Denis, 42 years old. My goal thru Instructables, is to share my little experience, my works and hacks : "Knowledge increases when we share it" !
Intro - why did I realize that?
The answer is so simple : just for fun :-)
A few of my main goals
  • maintain access to the HDMI port;
  • maintain access to the audio output;
  • maintain access to the GPIO;
  • maintain access to at least one USB port.
The BOM
Time
Between the first try, and the end, it took me about 75 hours.
Step 1: Using Wood ...
In the cleat (9mm*38mm*2m) :
  • 2 pieces with the following dimensions : 18,85 mm * 38mm
  • 2 pieces with the following dimensions : 10,6 mm * 38mm
In corner wand (9mm*38mm*2m) :
  • 4 pieces of 38mm height.
Step 2: It's Time to Use Tools
Here are the tools I used :
  • My favorite one is the Proxxon MF70 : this THE tool that allowed me to make the cuts with great precision !!
  • My Dremel (as important as the Proxxon ^^);
  • A multimeter, for some tests;
  • Some limes;
  • And the help of my son (8 years old) :-)
Step 3: Top Side
On the top side, I wanted to get this parts accessibles :
  • three swithes;
  • three push buttons;
  • the GPIO.
I do not give the precise details of the quotes, since it is according to your needs.
Note thoses details:
  • As you can see in pictures, I used some parts of wood to hold most parts ...
  • Again some wood to create the three push buttons ...
Step 4: Lateral Right Side
This side was the most complicated ...
I had to create the following holes:
  • for the HP (reused from an old laptop...);
  • for the USB, audio connector (reused from an old PC ...);
  • the charging port;
  • the HDMI port.
Step 5: Lateral Left Side
Nothing complicated on this side :
  • just some holes for the HP;
  • one aperture for audio amplifier;
  • 5 other holes to pass the optical fiber that I use to keep an eye on the battery level ...
Step 6: It's Time to Stick ...
Nothing complicated: glue and patience :-)
Time to drink a beer!
Step 7: How to Power ...
One of the most important think was the power ...
After googling for some example, I choose to use a power bank : this model has the advantage to be able to be used while charging :
  • Its capacity is done for 9600mAh, wich is enought to get at least 2 hour of autonomy;
  • I have removed the case, keeping battery and charge controller;
  • 5 LED indicators reveal the battery level => small parts of optical fiber allow me to see the level in front of the tablet;
  • A small piece of wood is used to hold the battery.
Step 8: LCD
I choose to use the original Raspberry Pi 7" touch screen
Unlike the different tutorials, I placed Raspberry upside down to save space.
I used two metal plates to keep it in the wooden structure.
Step 9: Final Assembly
After all this work, it's time to put all these elements together
Again, patience and a bit of methodology, and everything falls into place!
For the back plate, I used a piece of plexyglass ...
Step 10: And Now, the Result !
Be the First to Share
    • Puzzles Speed Challenge
    • "Can't Touch This" Family Contest
    • CNC Contest 2020
      CNC Contest 2020
    11 Discussions
    robbymcgee
    robbymcgee
    1 year ago
    Your woodworking skills are superior man. So I was wondering about the HDMI port, so technically you could still use an external monitor if desired, correct?
    D3ni3d
    D3ni3d
    Reply 1 year ago
    Hi Robby ;-)
    Thanks for your comment !
    And yes, you're right : I can plug it and use an external monitor -> it was one of my main goals :)
    keets
    keets
    1 year ago
    Really beautifull!
    What is the weight of the tablet, now it is finnished?
    D3ni3d
    D3ni3d
    Reply 1 year ago
    Hi Keets !
    Thanks a lot for your comment : the weight is about 850 gr ... I'm far away from a "classic" tablet : but ... classic tablets aren't made of wood ... and didn't have any GPIO port ^^
    keets
    keets
    Reply 1 year ago
    Hello D3ni3D!
    Thanks, 850 is not to bad in my opnion. Yes yours is made of wood and has a GPIO port.
    On the other hand there is a lot of things you don't have: Android troubles! I like the idea to run at Raspian and have full control over updates etc.
    BobM149
    BobM149
    1 year ago
    Great job on the tablet, the quality on the woodwork looks great! Just one question/comment... In step 2, you appear to be about ~10 years old, in step 6 your enjoying a cold Octoberfest beer......???
    D3ni3d
    D3ni3d
    Reply 1 year ago
    Hi BobM149 !
    Loool ^^
    Thanks a lot for your comment :-)
    In step 2, my son is helping me ... while in step 6, I take care of honoring the Oktoberfest ;-)
    allen
    allen
    1 year ago
    Would it be much of an issue to use a 10" touch screen? I see Amazon's got those for about $125.
    D3ni3d
    D3ni3d
    Reply 1 year ago
    Allen,
    To be honest and If I had to do a new one, I would probably choose a more large screen.
    In the other hand, choosing the original Raspberry LCD, I was sure of its compatibility : I think this is really the only point of attention, cause thez aven't got all the same connector ...
    D3ni3d
    D3ni3d
    Reply 1 year ago
    Hi Jason !
