Watch Winder
Introduction: Watch Winder
Hello,
I’m not sure if there are many others that are into Automatic Watches and have a box of K’nex.
I wanted to make a watch winder, this is what I’ve come up with
When using the 12v motor, you can purchase a wireless timer to have the watch winder come on and off as you like.
Teacher Notes
Step 1: Part List
Step 1 – Piece Count - sorry, no picture.
Blue rods - 29
Yellow rods - 11
White rods - 27
Green/Black rods - 14
Grey rods - 2
White connectors - 6
Blue connectors - 9
Red connector - 2
Purple Connector - 25
Orange connector - 22
Yellow Medium gear - 4
Large yellow gear - 1
Blue spacers - 9
Gray spacers - 8
End cap - 5
End cap loop - 4
Tan clip - 2
Total - 180
Step 2: Make Base
Step 2 – Base
There is room for the motor of your choice. I recommend the 12v plug in motor, as it will work with an app driven timer to turn it on and off as needed.
1- Parts for base
2- Make this for the bottom
3- Add Vertical rods
4- Upside down view
Step 3: Top
This will be the top
1 - Parts needed
2 - First part of the top
3 - Add this to the yellow rods
4 - Combine to make this
5 - Another view
6 - Make this
7 - Another view
8 - Combine to make this
9 - Top completed
10 - Upside down view
11 - Add it to the base and inside gears
12 - Another view Another view Another view
Step 4: Inside Gears
Step 3 – Inside Gears
1 - This is what it will look like
2 - Parts needed
3 - Add white and black rods to the 8 way connectors.
4 - Add gears and spacers with end caps as shown
5 - Add the other connectors
6 - Another view
7 - Another view
8 - Another view
9 - One more view
10 - Connect it to the base
11 - Another view
12 - Add the second inside gear
13 - Another view with both inside gears
Step 5: Top Gear
Top Gear
1 - Parts needed for the top gear
2 - Combine orange connectors with the white and black rods
3 - Use the yellow rods as shown
4 - Make this, back view of gear, note the gear orientation
5 - Alternate the orange connectors with the white and black rods
6 - Add the top gear to the base note the “snug” fit. It will be at angle as shown
7 - Another view
8 - Add watches with a small watch pillow – they come with some watches
9 - Another view
10 - View with 12v motor
11 - Battery motor and 12v motor
That’s it.
I do have other models I can post.
Creative Misuse Contest
Be the First to Share
    • Trash to Treasure Contest
    • Wearables Contest
      Wearables Contest
    • Fix It Contest
      Fix It Contest
