Introduction: K'nex - SPAS-12 Instructions
Hey guys, and today I bring you instructions for the SPAS-12 (Sporting Purpose Automatic Shotgun). The SPAS-12 is a duel-mode shotgun, it is able to fire in either pump-action or semi-automatic. The pump-action system would be used in riot control to fire non-lethal projectiles such as tear gas and bean bags.
Anyway let's talk about the SPAS-12, it's not my own design since I followed instructions from the Knexinnovation website which seem doesn't seem to work anymore. After building it, I went on to make several improvements and of course I have made instructions so you can have your very own SPAS-12.
Good Points
· Very Realistic
· Includes Folding Stock
· Comfortable Hand Grip
· Includes Pump-Action
· Good Iron Sights
Bad Points
· Uses Quite A Lot Of Cut Pieces (See Parts List)
· The Whole Gun Is Flimsy
· Doesn't Shoot Because It's Just A Model
Specifications For A Real SPAS-12
· Designed - 1972
· Number Built - Unknown
· Ammo - 12 Gauge
· Rate Of Fire - 4 Rounds Per Second If Using Semi-Automatic
· Powered - Pump-Action and Gas Acutated
· Magazine - 8 Rounds
. Range - Depends On Which Ammunition Is Being Used
In Call Of Duty: Zombies, the SPAS-12 is available in all Black Ops maps where it is only available from the Mystery Box for 950 points. It has a potential one shoot kill up to round 13 however the ammo count for it is very low. Speed Cola is very useful af decreasing the reload time of each shell. When it is Pack-A-Punched for 5000 points it becomes the "SPAZ-24" where you get more ammo, more damage, quicker reload time, bigger magazine and it also becomes fully automatic even though the player can still fire it semi-automatic. It has a one shoot kill up to round 20 but ammo can be a problem if using it fully automatic and the only way to get more ammo is through a Max Ammo power up.
Also check out my other creations and instructions
https://www.instructables.com/id/Knex-1975-CZ-75-Instructions/
https://www.instructables.com/id/Knex-Biplane-Instructions/
https://www.instructables.com/id/Knex-1976-MP5K-Instructions/
https://www.instructables.com/id/My-Knex-Weapons-Of-2013-2014/
https://www.instructables.com/id/Knex-James-Bond-Helicopter-With-Saws/
https://www.instructables.com/id/Knex-Galvaknuckles-Instructions/
Step 1: Parts List
If you have any trouble or need more pictures just leave a comment and I will get back you ASAP. I strongly advised you to collect all the pieces before you start building. Also I have added a few notes throughout this instructable to make it more easier to understand something if you run into any difficulty.
Green Rods - 259
White Rods - 92
Blue Rods - 20
Yellow Rods - 5
Red Rods - 1
Grey Rods - 7
Green Connectors - 10
White Connectors - 18
Blue Connectors - 8
Yellow Connectors - 143
Red Connectors - 43
Light Grey Connectors - 8
Dark Grey Connectors - 105
Orange Connectors - 75
Tan Connectors - 2
Tan Connectors (with the little tab cut off) - 1
Y Shape Black Connectors - 14
Black Socket End - 1
3.1cm cut rods - 14 (Some of them can be replaced with a blue rod)
3.3cm cut rods - 7 (For Pump-Action)
Yellow Connectors (cut, see step 4) - 3
Blue Spacers - 14
Push On Grey Gear - 2
Rubber Bands - 3
Total - 855
Step 2: Folding Stock
Step 3: Handle
Step 4: Barrel Part I and Pump-Action
Step 5: Barrel Part II
Step 6: Done
Well done you made it to the end, I do hope you have enjoyed building it.
Zombie Quotes About The SPAS-12
"Time to send those meat sacks back to hell"
"Ah the same weapon I used to kill my first wife, she was bitch"
"Honour will destroy those who are not worthy"
Thanks for building it, please leave a comment in the box below and subscribe
