Introduction: Knex 'Slider' Ball Lift
About: I'm into knex ball machine stuff. My favourite parts are lift/element hybrids, probably because I tried building a perpetual ball machine. It didn't work, of course. All my knex stuff is creative common, and …
This lift is quite like the 'alternator' lift, but at a 45 degree angle. It's also a lot more piece efficient.
It is also easily modified to get higher.
Video: http://youtu.be/LB3ykR_vr-I
Step 1: Making a Scaffold
This scaffold will be one blue rod wide. It has lots of red rods holding it up.
Make sure to add dark grey connectors to all of the grey rods.
Once you're finishing building this lift and you've attached it to your machine, you could potentially remove a lot of this scaffold.
Step 2: Slider
This is the bit that slides up and down.
Step 3: Adding That
Clip the previous step onto the dark grey connectors on the slope.
Step 4: Roof
This is the part that goes above the slider.
When the slider (Step 2) moves down, this part will prevent the balls from going down too.
Step 5: Attaching the Roof
Attach each of the blue rods from the roof to the scaffold.
Step 6: Entrance Track
This is where the ball enters the lift.
Step 7: Adding the Entrance
There are six places to connect the green rods.
Step 8: Motor Parts
This is the crankshaft and the motor.
Step 9: Putting It Together (Finished)
There are five connections to make.
Step 10: Troubleshooting
What if your slider Is jamming?
Put a spacer on any of the red rods like in the pictures.
What if the ball falls off the entrance too early?
See JimOfRedlands' comment below. He has suggested that the red connectors get replaced with green connectors in the entrance.
