Introduction: LED Bracelet
Sew your own LED bracelet and wear it!
Your bracelet will light up when you snap it together and close the circuit.
Sew your circuit, and then decorate it how you like!
If you're teaching this as a workshop, use my one-sheet pdf file below.
Check out the Seahawks and Valentine's Day variations!
I would like to thank Kylie Peppler of Indiana University for her inspiration and collaboration.
Step 1: Materials
Materials
a - conductive thread, 2 yards
b - needle threader
c - sewing needle (embroidery size 7)
d - battery holder
e - CR2032 coin cell battery
f - LED
g - hole snap ("innie")
h - prong snap ("outie")
(g and h are available as sets. I used size 3 snaps.)
Felt, 1 sheet for bracelet body (and 1 contrast color for embellishment)
Round nose pliers
Scissors
Ruler
Embellishments (optional)
Fun shapes for embellishment
Regular thread or embroidery floss
Beads and buttons
Fabric glue
Additionally, you may use clear nail polish to prevent the conductive thread from fraying.
Step 2: Test the Circuit
That means there is a positive (+) and negative (-) side to each component.
LED
- positive (+, longer): The positive leg of the LED is longer.
- negative (-, shorter): The negative leg of the LED is shorter.
- positive (+, "E"): The positive end of the battery holder looks like an "E" shape.
- negative (-, with slot): The negative end of the battery holder has a slot.
- positive (+, with writing): The top side of the battery has writing on it.
- negative (-, blank): The bottom side of the battery is blank.
- Touch the LED positive (+, longer) leg to the battery positive (+, with writing) side. See the LED light up!
- Touch the LED negative (-, shorter) to the battery positive (+, with writing) side. It won't light up.
Step 3: Twist the LED
- Twist the LED positive (+, longer) leg into a larger loop.
- Twist the LED negative (+,shorter) leg into a smaller loop.
Step 4: Cut the Felt
Step 5: Lay Out the Components
- Make sure that the LED negative (-, smaller) loop matches the battery negative (-, blank) side.
- The prong (outie) snap will be sewn on the top of the bracelet, nearest you.
- The hole (innie) snap will be sewn on the bottom of the bracelet, away from you.
Step 6: Sew the Components
- Sew all of the parts tightly, with small stitches. Use running stitch (sew in and out).
- Avoid long stitches: Longer stitches will make your circuit too floppy, and the connection may be bad.
- Try it on so you can check the length of the bracelet, and make sure that the length is sufficient for the circumference of your wrist.
Start sewing on the top of the bracelet:
- Thread the needle with conductive thread, and tie a knot in the loose end of the thread, opposite of the needle.
- Position the prong (outie) snap on the top of the felt, facing you. The second picture shows a close-up of the prong (outie) snap, after sewing.
- Start sewing with conductive thread at the prong (outie) snap.
- Sew from the prong (outie) snap to the LED positive (+, larger) loop.
- Sew through the LED positive (+, larger) loop three (3) times.
- Knot and cut the thread.
- Make a new knot on the loose end of the conductive thread, opposite of the needle.
- Start again at the LED negative (-, smaller) loop, sewing through the negative loop three (3) times.
- Sew from the LED negative (-, smaller) loop to the battery holder negative (-, with slot) end.
- Position the hole (innie) snap on the back of the felt, away from you. The hole (innie) on the snap should face out so the snap (outie) prong can fit in it.
From battery holder positive (+, "E") end to hole (innie) snap:
- Start sewing again at the battery holder positive (+, "E") end.
- Sew from the battery holder positive (+, "E") end to the hole (innie) snap.
- Sew the hole (innie) snap on to the back of the felt, away from you.
Step 7: Testing
Does it turn on when you snap it together?
If not, let's trouble shoot.
Do you have thread running across any component?
- The LED positive (+, larger loop) should not be connected to the LED negative (-, smaller loop).
- The battery top (+, with writing) should not be connected to the battery bottom (-, blank).
- If they are, then cut the thread, and resew each point.
- Your stitches may be making intermittent contact.
- Add some short stitches between components, or sew more stitches to tighten them down.
- Add stitches to tighten them down.
Step 8: Finishing
All done!
Decorate your bracelet with shapes, thread, beads, and buttons.
Add a flap to cover your battery holder, and leave room so you can change the battery!
I decorated mine as a wrist communicator device.
Share a picture of your finished bracelet on my facebook page! If you enjoyed this tutorial, check out my other e-textiles projects at www.bitwiseetextiles.com.
