Introduction: Legend of Zelda Embroideries + Pattern
About: Hi! I'm a slightly feral mountain hermit that likes to be helpful. I do community management at Instructables & Tinkercad. 🙌 Want to hear me chat about making? Search "CLAMP Podcast" on YouTube or your favorit…
I've been meaning to do some more Legend of Zelda embroideries for forever! It's one of my favorite game series, and the Game.Life 3 Contest finally got my butt in gear. :D These embroideries are framed in three inch wooden hoops, so it's easy to hang them up.
These Legend of Zelda embroideries took about me a couple nights of work, but you could make them go very quickly if you don't satin stitch them!
I've also included some patterns - you can find them on step two!
Step 1: What You'll Need:
  • fabric to embroider on - I'm using linen.
  • embroidery hoops if you'd like to frame them - three inches
  • acid free, clear drying craft glue that works on fabric and wood
  • patterns - included on the next step
  • embroidery floss
  • embroidery needles
  • pinking shears
  • a water soluble marking pen
You'll also need to know how to do a backstitch and a satin stitch. Unsure of what those are? Check out my how to embroider instructable.
This is a great beginner project because they're so small. :D
Step 2: How I Made the Pattern
I always like to trace the inside edge of the embroidery hoop so I have an idea about how much space you have to work with. These fit in tiny three inch hoops.
Then I draw my designs in pencil. When I'm happy with them, I trace over them with a pen or permanent marker. Then I erase the pencil marks.
I'm not big on using drawing programs, so I make every one of my embroideries like this. I use my scanner to resize them if I need it. :D
The patterns are attached to this step, including an updated ocarina! (please use the patterns for personal use only)
Step 3: Cut Your Fabric & Trace the Patterns
Cut your fabric slightly larger (1-2 inches) bigger than the hoop you'll be framing the embroideries in.
Then, pin a square of fabric over the embroidery. If you're using a thin fabric you might be able to see through it well enough to trace. If not, hold it up against a window or over a lightbox.
Use a water soluble pen to trace all your embroideries.
Step 4: Embroidering the Triforce
Use a backstitch to go over the outline, and then use a satin stitch to fill it in with yellow. This one goes really fast. :D
Keep in mind I am backstitching with three strands of floss and satin stitching with the full six strands.
Step 5: Embroidering the Rupees
Once again, use a backstitch to trace the outlines, and then fill in each rupee with a different color. I used red, green and blue.
When doing satin stitch, keep your stitches going in the direction the outside lines are going, it'll give the rupees more depth. :D
Step 6: Embroidering Navi
Do the outlines in a black backstitch. Fill in the wings with white, and then satin stitch white in the very center, surrounded by a light blue.
Step 7: Embroidering the Ocarina
Backstitch with black around the edges, and then satin stitch the holes in the ocarina with black. Stitch a small triforce (really, a triangle, haha) on the band around the mouthpiece. Then fill in the body and mouthpiece with color.
I chose a blue/green, but I think I'll go with a darker blue next time. :D
Step 8: Rinse and Dry Your Pieces
Rinse the finished pieces under cold running water to get out the water soluble ink. Hang them to dry. :)
Step 9: Mount the Embroideries in the Hoops
Center them as best you can. Pull the fabric taut and tighten them so it won't move about. :)
Step 10: Finish the Backs
Use pinking shears to cut all around the hoop edges. I normally leave a little less than a half inch of fabric.
Take your glue and put a line all around the edges of the fabric. Then press the fabric into the back of the wooden hoop. You might need to hold it down for a few seconds to get it to adhere. I never add a piece of fabric to cover the back of my work, but you can if you want to!
Step 11: And They're Done!
Please post photos if you make some! I would love to see them - and I've got some pro memberships I'll give out. :D
Epilog Challenge V
Epilog Challenge V
Game.Life 3 Contest
Game.Life 3 Contest
