Introduction: Literary Clock Made From E-reader
About: I play with electronics and stuff. Also manager of the electronics workshop at the Royal Academy for Arts (KABK) in The Hague.
My girlfriend is a *very* avid reader. As a teacher and scholar of English literature, she reads eighty books per year on average.
On her wishlist was a clock for our living room. I could have bought a wall clock from the store, but where is the fun in that? Instead, I made her a clock that tells the time by quoting time indications from literary works, using an e-reader as display, because it's so incredibly appropriate :-)
It updates every minute, so for instance at 9.23 in the evening, the Kindle will read
My father met me at the station, the dog jumped up to meet me, missed, and nearly fell in front of the 9.23pm Birmingham express.
The way I made this, the Kindle can still be used as a normal e-reader. If the clock is turned on though, as an added bonus, it doubles as a literary quiz. The clock shows the quotation without the title and author of the book, so you can guess. If you want to know the answers, pressing the buttons on the side (normally used to advance pages of e-books) will reveal them.
Update August 5 2018:
Thank you all very much for all the nice compliments! Also, the feedback has been very useful. If you have any trouble making your own Kindle clock, please see the comments.
This Instructable has been featured on Hackaday, Gizmodo, The Verge and Hacker News. I am one very proud and happy maker :-)
Meanwhile, Johannes Enevoldsen made a web version of my clock, as did Davide. I am excited that my project inspired theirs.
Update 26 October 2025:
If you liked my literary clock then you might enjoy this product: the NovellaMate. They found over 180,000 time-related quotes in books! 😮 Their KickStarter starts in November (I am not involved but they did send me one to test it).
Step 1: Tools and Materials
Really the only thing needed is an e-reader (and a USB cable to connect to it). For this project, a Kindle was donated to me by a friend. It is a Kindle 3 WiFi (nicknamed K3, or K3W). You will find many second-hand earlier models like that on eBay for instance.
You'll need a computer (any operating system), with an SSH client like vSSH and an sFTP client like Filezilla installed (both are free). It helps to have a bit of experience with Linux, because that is what the Kindle runs on.
To have the Kindle stand upright in our cupboard, I made a stand from concrete. If you want to do the same, you'll need a food container in a shape you like, cling film, styrofoam, cement, hot glue or double sided tape, and a bucket (to mix the cement).
Step 2: Jailbreaking the Kindle
In order to change the Kindle into a clock, we need to get into the system files. In order to do that, we need to open it up through a process called 'jailbreaking' (don't worry, it's not illegal if it's your property). An explanation to jailbreak the Kindle and a zip file with the necessary files can be found here. Also see this overview of all available software custom software. Find out which Kindle model you have on this page.
For this project, you only need to install the jailbreak hack and the usbnet hack, not the screen saver hack. USBNetwork will grant you remote shell access to your Kindle, either over USB or WiFi. What you will need, if you want to use the keyboard's keys, is the Launchpad hack.
Warning: I read this can potentially ruin your Kindle. Follow the instructions. Jailbreak at your own risk.
If you connect the Kindle to your computer, it will show up as an USB drive.
Basically, all you need to do is put Update_jailbreak_0.13.N_***_install.bin (where *** is your Kindle version, in my case 'k3w') in the root folder of the Kindle when it is connected to your computer.
From the README file in the zip file: "Now, eject & unplug your Kindle, and go to *[HOME] -> [MENU] > Settings -> [MENU] > Update Your Kindle*. It should be quick.” (note: that's two times clicking the menu button).
Then do the same for the USBNet and Launchpad files. You should now be able to log in to the device using SSH. On the Kindle, connect to the WiFi network. One way to find out its IP address is by logging into your WiFi router and looking it up there. Username is 'root', and the default root password for your model can be calculated.
Then install Python on the Kindle, again using the files on the excellent Mobileread.com forum (thanks VoltaX2 in the comments below).
Step 3: Making an Image for Every Single Minute of the Day
There are 1,440 minutes in a day. Compiling a list with quotes for each and every one of them from different literary works is a massive undertaking. Big relief: others already did that for us.
In 2011, newspaper The Guardian asked its readers to submit quotes from books which mention times. They wanted to build an installation for a literary festival. So they have two versions of a list on their website (1, 2).
I combined the two lists, cleaned them up, added a few times I found myself, and turned them into one CSV file.
Unfortunately the list does not cover all minutes of the day. I worked around this by using some quotes more than once, for instance if it can be used both in the AM and PM. More vague time indications can be used around a certain time, so this quote from Catcher in the Rye is used at 9.58AM: "I didn't sleep too long, because I think it was only around ten o'clock when I woke up ... "
Even with this pleasant list, two things took me an unreasonable amount of time. I needed to turn every single quotation from the list into an image. I wanted to make them fit nicely to the screen, so the font would be as large as possible for each quotation.
While scaling a text box to a certain height and width is easy to do manually in most photo editing software, it would have been an immense amount of work to create them one by one. Creating a script to do it for me however proved to be quite the task as well. In PHP (I used that programming language because it has nice functions to deal with text) I wrote a recursive function to find the best fit for each quotation, long or short. For each line, the script creates two PNG images, one with and one without metadata.
It uses the Libertine font, which I like because of its stylish look, because it is very complete (numbers, punctuation, diacritics) and because it's open source.
The other thing that took me a long time is identifying all time mentions in the quotations, because I wanted to write them in bold text. That makes the clock easier to use, especially when a quote is quite long. The problem is that in books, an impressive variation of time descriptions is used. It can be anything from '6.00 p.m.' or '18:11:00' to '0600h', 'around six o'clock', just 'at six', or 'twenty-eight minutes past eleven'. I made a script to try and find most of these variations, did the ones it couldn't find myself, and added them to the csv file.
If you want to make your own Kindle clock, you may use my scripts (find them attached below), but you can also just download all the resulting images.
Step 4: Starting and Stopping the Clock
I wanted to be able to start my literary clock by pressing the shortcut Shift+C on the small keyboard of the e-reader. Pressing it again stops the clock and turns the clock into a normal e-reader again.
First, create this folder: /mnt/us/timelit and then put the scripts I attached below in there.
The images (see previous step) go into /mnt/us/timelit/images and /mnt/us/timelit/images/metadata/
When you install the Launchpad hack, the folder /mnt/us/launchpad is created. Create a new file there called startClock.ini and put this text in there:
[Actions]C = !sh /mnt/us/timelit/startstopClock.sh &
That creates the shortcut Shift+C. If we press that, the bash-script startstopClock.sh starts. It stops the Kindle framework (the normal user interface), prevents the Kindle from going into power save mode and creates a small file (/mnt/us/timelit/clockisticking) to indicate the clock has started.
Note: Shift+C on the Kindle is really 'press shift, let go, press c'.
If the user presses Shift+C again and the clockisticking file is already there, startstopClock.sh will remove it and restart the Kindle.
startstopClock.sh also executes another script, showMetadata.sh, to enable the keystrokes that will show the metadata (using the command /usr/bin/waitforkey). If the user pushes the 'next page' button on the sides of the Kindle, it will check if the clock is ticking and if it is, will show the same image as currently is shown (which file that is, is saved in the clockisticking file) but then with title and author at the bottom.
Changing the time on the display every minute is done by adding this line to /etc/crontab/root:
* * * * * sh /mnt/us/timelit/timelit.sh
and then restart crontab like this: /etc/init.d/cron restart
Every time it is run, timelit.sh checks if the 'clockisticking' file is created. If it is, timelit.sh proceeds to show the image for the current minute.
Note: you'll probably want to change the timezone in timelit.sh where it says 'TZ=CEST'.
Step 5: Making a Stand
I was inspired by other Instructables to make a concrete stand for my Kindle clock. I could also have made something out of wood (or even a book), but I liked to try cement because I never did before and also because I thought the grey color would go nicely with the e-reader.
I cut a piece of styrofoam the size of the e-reader, plus a little extra for the USB cable to go in. I wrapped it in cling film and a bit of clear tape, so the cement would come off easily afterwards. I taped it to the bottom of the food container using double-sided tape.
Then I mixed enough cement to fill the food container to about 5 centimeters (2") deep. I'm not sure, but I may not have used enough water, because the cement was less pourable than I had expected. I definitely should follow the concrete class before my next try :-)
I put the cement in the container using a garden shovel, tamped it a bit, and then let it dry for two days.
The next time I will try for a smoother surface by first sifting the cement to get rid of the small rocks, adding a bit more water and spend more time sanding the result. Then I will also make a small recess in the base so the USB cable goes to the back of the stand. This can be done using a straw.
Step 6: Further Ideas
The literary clock looks really nice, and the quiz part works well. My girlfriend now and then checks to see from which book a quotation is from (she usually guesses correctly :). The stand did not come out quite how I hoped, but I'm looking forward to trying making a better one.
I will probably also add a lamp, either clamped on the device or incorporated into the new base. When the clock sits in the cupboard, sometimes it is a little too dark to be able to tell the time.
Instead of getting power for a lamp separately, one could power a lamp using power from the hinge slot in the Kindle. Two slots are there for Kindle cases that have a lamp built in. You'd have to open the Kindle and do some soldering, or make your own metal clamps, but that would be sweet. One could even connect a light sensor, so the lamp will only switch on when it's getting dark.
Extra features I hope to get round to are
  • having the clock stop between 1am and 6am, to save power
  • turn of wifi for the same reason, but turning it on daily for a couple of minutes to synchronise the system clock
  • showing the percentage of the current minute that has passed as small blocks at the bottom, just like the Kindle indicates the progress the reader is making in a book
  • show a warning when the Kindle's battery is running out
(these last two could be done by overlaying small images on the larger image using the Kindle's eips command, see my scripts for examples).
Other possible ideas are
  • using keys on the Kindle to set the time
  • show a default image when the clock starts and/or when no image is found
  • using a shortcut (shift-Q for instance) to toggle quiz mode
  • have the Big Ben sound chime at the top of the hour (only during the day), as the Kindle has a nice speaker built in. Other sounds could be the sound of slamming a book shut or turning pages or even reading out a quote.
I hope you like the idea and this Instructable. Let me know if you have any questions or suggestions!
