Introduction: Make Custom Guitar Cables on the Cheap
Hi there
I just want to share a Quickie project , Guitar cables on the cheap
Great for the guys that like to have exactly what they Want , using The
'The 3 B's Technique ' :
Bueno
Bonito y
Barato
That means Nice , Cool And Cheap in spanish
Soon (in the next step) i'll be posting the Complete details
Bueno
Bonito y
Barato
Step 1: Find Your Stuff (materials)
This is the mandatory list of materials , i'm giving several examples
of raw materia to properly fit your needs or taste
For The plug :
use a 1/4 inch connector not to big and must be take-apart-able (that word exist?)
Option A) A regular plastic body , plug
Option B)A Metalic body , plug (Recommended)
Option C)A silver body And Silver (Ag) plug
Option D)A Gold (Au) plated body and plug
For The Cable Itself :
Must be single Conductor core And Shield (A copper mesh around the core)
Option A) Normal duplex style wire
Option B)Audio microphone cable (recommended)
Option C)Silver Core , Oxygen-free Shielded Cable
This Cable is as You like It , Cheap , Good or Nice
I decided for the good quality cable
The Final cost was:
About 2 dollars of 6 feet of wire
About 1.5 dollars For Each plug
And 3 dollars of silver solder and Heat shrink tubing
I also took some Zipties from my junkbox
So for Everything was 8 bucks , Great!
For The plug :
The Final cost was:
Step 2: Tools Needed
For the Proper assembly you will need :
@Soldering Iron ( 30 - 45 watt recommended)
@Needle Nose Pliers
@Wire Cutters
}A Lighter
}A small cloth
} Small , Precision scissors
Optionally you can use
A wire stripper
A hot air gun
Some hemostats
And a Multimeter to test connections
@Needle Nose Pliers
@Wire Cutters
}A Lighter
}A small cloth
A wire stripper
A hot air gun
Some hemostats
Step 3: Strip and Twist the Wires
Using Your Wire Cutters (stripper) Remove the Black , Principal Insulation
Then You'll See A small Cable surrounded by A thin Copper wire mesh
Grab and twist together the copper mesh strands
Then peel The Small Cable (core ) , And Twist The Strands
Optional : dip the wires in solder paste to achieve better tining and soldering
Repeat With the Other End
Step 4: Plug in the Soldering Iron and Tin the Wires
Plug in The Soldering Iron
Wait 5 minutes And Tin the Tip
After That
Put the cable in your Repaireed helping hands if Desired
Put The Tip of the iron in thevery end and slide the solder from front to the back
Here's A Video Demo
Apologize my dirty soldering skills
Repeat With the other Side
After That
Here's A Video Demo
Step 5: Cut a Piece of HST and Dry Fit the Plug
Cut A small piece of shrink tubing , of the size of the Small (Core) insulation ,
the Picture will give you instructions on how
Then Put the Plug on and insert the wires in their respective holes
The small tab with a hole in the center of pother lug is for the wire were
you insert the tubing ( The Core ) And the Other strand to the body of the plug
The pictures will give reference
Step 6: Solder , Shrink and Crimp
Solder the wires to their respective tabs , clip the excess wire
Then using your lighter or Hot air gun , shrink the tubing were the connection was made (Use Picture As Reference )
Using your pliers , crimp the wire , were the strain relief tabs are .
Step 7: Apply 1/2 Inch Heat Shrink Tubing
Then Slide a 2 inch piece of 1/2 heat shrink tubing And Shrink it With Your Lighter or heat gun
Step 8: Add the Second Layer of HST
Now Slide As much as you Can a 2 inch piece of 1/4 HST , Then Shrink With a Heat Source
Step 9: Insert the Metallic Body and Spring Strain Relief
Now Insert The Spring And The Round Metallic Body . Screw It And Clean With A Cloth
Congratulation You've Finished The First Side
Step 10: IMPORTANT WATCH THIS BEFORE DOING ANYTHING ELSE!!!!!!!
Before Doing Anything else Insert The HST and The Body Before Soldering . Or else You'll have to desolder everything and start again
Step 11: Cutting More HST and Soldering Again
Cut The Small HST for The Other Core Cable , Slide It In place
Solder The Connections , like about ten minutes before (Shield to body , Core To Tip)
Clip Excess Wire
Shrink The Tubing
Clip Excess Wire
Shrink The Tubing
Step 12: Slide and Shrink More HST
First , Slide some 1/2 inch HST , Then Shrink
Then,Slide 1/4 inch tubing And Shrink
Pretty Self-explanatory , Isn't it ?
Step 13: Finishing and Final Thoughts
Slide The Spring , Then Screw the Body And....
YOU"RE DONE !!!11!
In the last 30 minutes you've done a Quality , Custom Made guitar Cable
Spending less than 10 Bucks , Could it be better ?
The Resistance (impedance) is comparable with Fender And Yamaha Cables (1.7 and 1.9 é )
Having just 2.1 é average , Great
Here's the video test
Thanks For Watching
YOU"RE DONE !!!11!
Thanks For Watching
