Introduction: Make Emergency Homemade Spare Key With TicTac Bottle or Credit Card in 2 Minutes
Make a Key in minutes By using Expired Debit Or Credit bank card or any similar type cards or an Empty Tic tac mints plastic container we can make emergency spare key for lock, The resulted key can be used up to 10 times because its not metal it will bend so make it in less than 4 mins and keep in your wallet and use i an forgotten or an emergency situation.It is the most Usefull and easiest life hack using plastic bottle or a card.
Requirements:
Tictac container
unused gift or expired cards
Clear tape and a
lighter or a candle
Step 1: Take the Necessary Things
take empty tictac bottle or unused bank card or any other similar cards and take the original key and lighter or a candle and now we get into our work
Step 2: Smoke One Side of the Key
use lighter and flame one side of the key smoke accumulates on the surface of the key now place key aside and let it cool down
Step 3: Make the Trace of Key
By using the clear tape stick it on the smoky side of the key and the print of the key transfer to the gummy surface of the that means smoke particles sticks to tape and it gives clear print of the key
Step 4: Sticking Tape on Card and Cutting
Stick the tape on the card and by using the scissor cut it exactly take time for exact cutting if you are not good at cutting after cutting your key is ready
Step 5: About Key
In the above picture you can see the cut portion of key matched to the original key so cut softly and exactly
Step 6: Using Tictac Mint Container
I made similar spare key with tic tac bottle in the same way
Step 7: Test
After making test them they will work , after making several keys i got to know they will work up 10 to 15 times because they are plastic they will bend but even though it is cheap home made trick to copy key and use them in emergency situation make it and keep it in your pocket it will be useful at any time
Thank you
Bye Bye
