Introduction: Make NES Music With LMMS
About: I build projects using arduino nano / esp32 / arduino micro and also arduino mkr1010
LMMS has a module named Nescaline that reproduces NES sound.
We are going to use this free music production software, to make music, 8bit style!
  • First we will take a look at LMMS interface
  • Then we will learn how to create a pattern
  • Finally, we will create our song
We are going to use a premade session already setup to make NES music.
There are also examples, check them out!
As always all documentation/files are available on github in english/french : http://github.com/tutoblender/lmms_nes
Step 1: LMMS Interface
Before we start, let's take a look at LMMS Interface, if you have already use Fruity Loop, this should looks familiar.
  • Piano Roll : where you create a pattern : a group of notes
  • Song Editor : where you use your patterns to create a song
  • FX Mixer : where you can set the volume of each instruments
  • Instruments : Click on CH1/CH2/CH3/CH4 in the song editor to display the instruments.
Here we have 4 instruments, each instruments is assigned to the 4 channels of our nes
  • CH1 / CH2 generates pulse wave, for the melody
  • CH3 generates triangle wave, for the bass
  • CH4 generates noise, for the percussions
For more information, check out this two videos on youtube
Step 2: Create a Pattern
We will now see how to create a pattern, each pattern consists of 1 or more measure.
To create a pattern, go to the song editor :
  • Click on an empty box on the instrument you want
  • Double-click on the box to display it in the piano roll
We can now create our pattern in the piano roll.
  • Create a note: Left-Click on the piano roll
  • Move a note: Left-Click on a note
  • Resize a note: Left-Click on the right corner of the note
  • Delete a note: Right-Click
  • Play the pattern : Space bar
Step 3: Create a Song
If you want to hear all the patterns:
Click on the song editor and press the Space Bar
Create a loop
By default, the song will not loop
  • Turn on/off loop : Left click on the two green triangles (Enable/Disable loop points)
  • Move loop start : Middle-click
  • Move loop end : Right click
Copy/Paste a pattern
  • Left-Click on an empty box where you want to copy your pattern
  • Right-Click on the pattern / Copy
  • Right-Click on the empty pattern / Paste
You can erase a pattern with a middle click
Step 4: Modify Instruments
Try to modify each instruments, each channel is on his own line.
  • VOL : Volume
  • CRS : Tuning (Note by note) (1 --> C3 become C#3)
  • ENV/LEN : Reduce length of note
  • ∞ : Repeat note
  • Width : Change sound
  • Sweep/AMT/Rate : Change pitch of notes progressively
  • Note : Noise changes depending of note
  • Mode : Noise sounds more metallic
Step 5: Summary
Here for the basis, I hope it's inspired you to make rad old-school music (It's so bad!)
If you made a music using this tutorial, Please post it in the comments!
