Introduction: Make Your Own Electric Motorized Longboard
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to build an electric motorized longboard from scratch. It can reach speeds up to 34km/h and travel up to 20km with a single charge. The estimated costs are around 300$ which makes it a good alternative to commercial solutions. Let's get started!
Step 1: Watch Part 1 of the Video Series!
During the first part I will show you how to build the longboard itself. The process is rather simple but you can always get yourself an already completed board from your favorite seller. The method of attaching the motor and the electronics later on stays the same.
Step 2: Board Template & Parts List for Your Homemade Board!
Here you can find the board template that I used during the video. Don't forget to print it out as a poster otherwise your board will be a bit small.
The materials you need for your own longboard are the following (affiliate links):
Home Improvement Store:
2x 55x122cm 4mm thick beech plywood
1x 55x122cm 6mm thick beech plywood
2x 550g waterproof wood glue
1x wood glaze (walnut)
Aliexpress:
1x Longboard Kit: https://s.click.aliexpress.com/e/_d6w9w3l
1x Grip Tape: https://s.click.aliexpress.com/e/_d7q4HQP
Amazon.de:
1x Longboard Kit: http://amzn.to/1TEUgpy
1x Grip Tape: http://amzn.to/1klBxTE
Step 3: Watch Part 2 of the Video Series!
In this second part of the trilogy I will show you the mechanical build. This includes attaching a gear wheel to one wheel, milling an adapter to connect the motor to the already mentioned gear wheel and finally mounting the cases for the electronics onto the board.
Step 4: Adapter.svg File & Parts List
Here you can find the .svg file I created for the adapter. Open it with Inkscape in order to print it out as a template or to modify the design.
You will need the following parts to complete this step (affiliate links):
1x 120x1000mm 0.5mm thick steel sheet
1x 160x100mm 10mm thick aluminium
2x cable gland
Ebay:
1x 400kV 1560W Motor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
or http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Gear System: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
2x 22.2V 5000mAh LiPo Battery: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
1x 70A ESC: http://rover.ebay.com/rover/1/711-53200-19255-0/1...
5x XT60 Connector: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 7 Pin Balancer Extension: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x 3 Position Toggle Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress:
1x 400kV 1560W Motor: https://s.click.aliexpress.com/e/_d8Bo2RN
2x 22.2V 5000mAh LiPo Battery: https://s.click.aliexpress.com/e/_dXPvyiT
1x 80A ESC: https://s.click.aliexpress.com/e/_dVnaBPt
5x XT60 Connector: https://s.click.aliexpress.com/e/_d7rt0sn
2x 3 Position Toggle Switch: https://s.click.aliexpress.com/e/_d9dxPD5
Amazon.de:
2x 22.2V 5000mAh LiPo Battery: http://amzn.to/1N0qLcl
1x 80A ESC: http://amzn.to/22TtTCt
5x XT60 Connector: http://amzn.to/1LUS0HX
2x 3 Position Toggle Switch: http://amzn.to/1GlYVHo
Step 5: Watch Part 3 of the Video Series!
In the final part of the trilogy I will talk about the wiring inside the cases and how I created a remote control from an old Wii nunchuk I had laying around.
Step 6: The Wiring!
Here you can find the wiring diagram that you need to follow in order to achieve the same functionality. Make sure to only switch on one battery at a time. Otherwise you would charge the empty battery through the full one and the ESC might not function correctly. But don't worry nothing would explode if that mistake happens.
For the wiring I used 12AWG red and black wire: Here is an example: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Step 7: Build the Transmitter and Receiver Circuit!
Here you can find all the schematics, code and board layouts that I created for the transmitter and receiver.
Make sure to upload the Attiny Sketch to your ATtiny45 if you want to finalize your nunchuk remote control.
You will need the following parts for this step (affiliate links):
Ebay:
1x STX882 Transmitter, SRX882 Receiver: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x NE5534: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x ATtiny45: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Slide Switch: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 300-380mAh 3.7V LiPo Battery: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Charging/Protection Circuit: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
3x 10k Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Micro USB Board: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Aliexpress:
1x STX882 Transmitter, SRX882 Receiver: https://s.click.aliexpress.com/e/_dZNyOB9
1x NE5534: https://s.click.aliexpress.com/e/_dXhNVER
1x ATtiny45: https://s.click.aliexpress.com/e/_dYnbbCb
Amazon.de:
1x NE5534: http://amzn.to/1MHZjp7
1x ATtiny45: http://amzn.to/1ZkjVe4
Step 8: Success!
You did it. You just built your own electric longboard from scratch. Make sure to share your pictures in the comment section.
Feel free to check out my YouTube channel for more awesome projects:
https://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
