Introduction: Make a Simple Leather Apron
This is a very simple tutorial for making a leather apron for use in your wood shop or just for use around the house. Aprons come in handy for all sorts of things and can be exceptionally customizable. There are a few simple steps to follow to get the perfect apron for you.
- Select and Cut Your Leather
- Chose Your Pocket and Strap Layout.
- Sewing/ Rivet construction
- Finishing.
So let’s get started
Step 1: Choosing Leather and Cutting the Pattern
When making an apron there are a lot of potential factors to take into consideration such as weight, cost, and area of use. These will play into your design. I strongly suggest going to a local leather store and talking with them if you are unfamiliar with the different cuts, weights, and tanning methods.
Here I used something light because this will not be used for anything super hot or messy. I was actually asked to make this one for a friend’s blacksmith costume. Choose something you believe will be appropriate for your use and has a large enough area free of major defects. Once you’ve chosen your material it’s time to cut to shape.
To get the right shape I used a cloth apron and used that for my general outline. Then I used shears but you can also use a good sharp knife to cut out the outline shape.
Once that was done I grabbed a piece of opposing color for the pockets. I cut out some general shapes from that piece to use later. With that we are ready to move on to the really fun part.
Step 2: Pocket and Strap Layout.
Step 3: Construction
The pockets also used contact adhesive but were then outlined with diamond stitching chisel and hand stitched. I typically saddle stitch everything as it has a lot of strength and versatility. This will take some time so you could opt for some well placed rivets but know that it will probably cost you in value over the long term.
Once all the straps and pockets are placed you are ready to move on to finishing
Step 4: Finishing
Once that has dried you can buff to a high shine and it is ready to go.
