Introduction: Making a Mini Leather Bucket Bag
Today, Ill make a BTS Armybomb leather bag
Step 1: Design & Sketching
I Sketched refering to the Army Bomb
I sketched it, imagining a cylindrical bucket bag
Step 2: Cutting Bottom Part
Cut the leather off the bottom
I used a circular cutter
If you don't, you can cut them with a pattern
Step 3: Making Bottom Side
Make a strap to attach to the side of the circle
Step 4: Stick Bottom and Bottom Side
Apply glue to the edge of the band you have made
When Bond dries, put it according the center mark
Sewing the outside of the attached bottom part
Step 5: Cutting the Main Body Parts
Cut the leather according to the pattern
Make holes in the circle in the pattern
Make two of it
Step 6: Combine Main Body With Inner Side Band
Cut the strap that will be attached to the inside of the main body (in the pattern)
Body : Bond the 5mm edge section
Attach the main body with the strap
And Make a stitch holes
Step 7: Cross Stitching
Attach it to the cross-stitch
Step 8: Cross Stitching 2
Repeat the other side in the same way
The X stitch takes a long time, but the results are pretty
Step 9: Combine Body and Bottom Part
Next, it'll combine the body and the bottom
Step 10: Add Bias Top Edge
Bias leather thickness is 0.4t
Wrap it up
Step 11: Making a String
Make a string that tightens the entrance
I've put in reinforcements for string reinforcement
Step 12: Making a Shoulder Strap
Shoulder straps thickness is 1t
If you cut and fold the end into pattern, It's in a semicircle form
Sewing the entire edge and Sew the straps and the body
Step 13: Done :-)
Thanks for watching!
