Introduction: MangoCube WiFi in AP(Access Point) Mode
This Instructable shows how to Configure and use MangoCube WiFi in AP mode.
things you will need for this;
1. MangoCube WiFi or (WiFi board+ Arduino UNO/Leonardo board)
2. Mobile phone Android or iOS with Wi-Fi functionality
3. TCP terminal App for your Smart phone
Step 1: Set MangoCube WiFi to Work in AP Mode
Please check out the Step:1 of this Instructable to know how to enter MangoCube WiFi in command mode.
https://www.instructables.com/id/MangoCube-WiFi-wit...
Once in command mode;
use following commands to set MangoCube WiFi in AP mode;
AT+WMODE=AP
AT+Z
check the image for more info.
Step 2: Connect to MangoCube WiFi's Network
Once MangoCube WiFi is set up to work in AP(Access point) mode it will appear as other Wi-Fi networks that you can connect to.
check the images to know more.
Once MangoCube appears in available WiFi networks use your smart phone (Android/iOS) to connect to.
Note: By default MangoCube connection is open(unsecured) if you want you can set security parameters, please refer to user manual.
Step 3: TCP Terminal App
Use any TCP Terminal App suitable for your OS (i.e. Android/iOS)
SocketClient App for Android is used in this example.
Then Connect with following parameters;
Server IP : 10.10.100.254
Port : 8899
Once connected the MangoCube WiFi and Smart phone works in Serial connection, meaning Data send from TCP Terminal App will be received by MangoCube WiFi and vice versa.
