Introduction: Mass Effect Crochet: Liara T'Soni and Glyph
I also made Tali Zorah vas Normandy, check her out here.
Step 1: What You Will Need
Yarn weight 4:
- Blue
- White
- Grey
- Black
Other:
- 2.25mm crochet hook
- Yarn needles
- Blue embroidery thread
- Polyfil/fibrefil stuffing of some sort
- Blue, light blue, grey, black and white felt
- Velcro
- Small LED light with switch and battery (I found these LED push pins at a dollar store which have the LED, battery and switch all in one small package -they are great for adding a light to these types of projects)
Rnd round
ch(s) chain stitch(s)
sc single crochet
sl st slip stitch
st(s) stitch(s)
sc2tog decrease by crocheting 2 stitches together
Step 2: Head
With blue yarn
Rnd1: Magic Circle 6
Rnd2: 2sc in sc 12st(s)
Rnd3: *2sc in sc, sc, repeat from * -18st(s)
Rnd4: *2sc in sc, sc, sc, repeat from * -24st(s)
Rnd5: *2sc in sc, sc, sc, sc repeat from * -30st(s)
Rnd6: *2sc in sc, sc, sc, sc, sc repeat from * -36st(s)
Rnd7-16: sc in sc, -36st(s)
Rnd17: *sc2tog, sc, sc, sc, sc repeat -30st(s)
Rnd18: *sc2tog, sc, sc, sc, repeat -24st(s)
Rnd19: *sc2tog, sc, sc, repeat -18st(s)
Rnd20: *sc2tog, sc, repeat -12st(s) Now is a good time to stuff.
Rnd21: sc2tog in rest
Fasten off. Leave tail.
Step 3: Crest
Rnd1: ch(s)12, sl st in first, -12st(s)
Rnd2-3: sc in sc -12st(s)
Rnd4: sc2tog first two, sc in rest -11st(s)
Rnd5-14: continue sc2tog first two, sc in rest in each row until 1st left
Fasten off. Weave in end and stuff.
Step 4: Torso
With white yarn
Rnd2: 2sc in sc -12st(s)
Rnd5-12: sc in sc -24st(s)
Rnd13: *2sc in sc, sc, sc, sc repeat from * -30st(s)
Rnd14: sc in sc, 30st(s)
Rnd15: *2sc in sc, sc, sc, sc, sc repeat from * -36st(s)
Rnd16-18: sc in sc, -36st(s)
Rnd19: *sc2tog, sc, sc, sc, sc repeat -30st(s)
Rnd20: *sc2tog, sc, sc, sc, repeat -24st(s)
Rnd21: *sc2tog, sc, sc, repeat -18st(s)
Rnd22: *sc2tog, sc, repeat -12st(s) Now is a good time to stuff.
Rnd23: sc2tog in rest
Step 5: Feet
With grey yarn, make 2.
Rnd3: *2sc in sc, sc, repeat -18st(s)
Rnd4: *2sc in sc, sc, sc, repeat -24st(s)
Rnd5-6: sc in sc, -24st(s)
Rnd7: *sc2tog, sc, sc, repeat -18st(s)
Rnd8: *sc2tog, sc, repeat -12st(s) Stuff .
Rnd9: sc2tog in rest
Step 6: Legs
*Note: I ended up making the legs shorter than those that appear in the photo, I originally had the grey and black portion the same size. I thought that they were too long so I shortened the grey part of the legs to 3 rounds instead of 5, the pattern will reflect this.
Starting with black yarn, make 2.
Rnd1: Magic Circle 4
Rnd2: 2sc in sc -8st(s)
Rnd3: 2sc in first, sc, sc, sc, 2sc in next, sc, sc, sc -10st(s)
Rnd4-7: sc in sc -10st(s)
Switch to grey yarn
Rnd8-10: sc in sc -10st(s)
Rnd11: sc2tog in first, sc, sc, sc, sc2tog in next, sc, sc, sc -8st(s) Stuff.
Rnd12: sc2tog in each
Fasten off, Leave tail.
Step 7: Arms
Rnd3-4: sc in sc -8st(s)
Switch to white yarn
Rnd5-12: sc in sc, -8st(s)
Stuff it. Fasten off. Leave tail.
Step 8: Coat and Leg Armor
With white yarn
Row1: chs 25,turn -25st(s)
Row2: sc in each chs, ch1, turn -24st(s)
Row3: sl st in first 2 sc, sc in next 18 sc, ch1, turn -18st(s)
Row4-8: sc in sc, ch1, turn -18st(s)
Row9: 2sc in first 3 sc, and last 3, sc in rest, ch1, turn -24st(s)
Row10: sc in sc, ch1, turn -24st(s)
Row11: 2sc in first 3 sc, and last 3, sc in rest, ch1, turn -30st(s)
Row12: sc in sc, ch1, turn -30st(s)
Row13: 2sc in first 3 sc, and last 3, sc in rest, ch1, turn -36st(s)
Row14: sc in sc, ch1, turn -36st(s)
Leg armor
With white yarn, make 2
Row1: 6ch(s), turn -5st(s)
Row2: sc in each ch, ch1, turn -5st(s)
Row3-11: sc in sc, ch1, turn -5st(s)
Fasten off. Weave in ends.
With blue embroidery thread stitch along the edge of the coat and leg armor to simulate piping.
Step 9: Finish the Body
- I cut out a few thin pieces of blue felt for the straps on Liara's coat the top two pieces I glued on.
- For lower one, the belt, I wove it through the crochet holes in the coat. I also added the small grey squarish piece at the back.
- Once the coat was finished I sewed it onto the torso with regular sewing thread. I left the areas below the belt unsewn, so that the coat can be folded back to fit the legs.
- I then sewed on the arms.
Step 10: Legs and Feet
- I wrapped the armor around the legs and stitched it on with blue embroidery thread so that it looks like straps
- Sew the feet to the legs
- Sew the legs to the torso. The legs were arranged so that Liara is in a seated position.
- I then sewed a small piece of velcro (hook side) to Liara's hands so that she can hold Glyph.
Step 11: Finish Head
Step 12: Face
Rnd 1: Magic circle 4
Rnd2: sc in sc -4sts
I created the eyes with blue, black and white felt and glued them on. I made knots with grey yarn for the freckles. I then sewed the nose to the face. I was going to make a mouth with embroidery thread but I just couldn't get it to look right. Once the face was done I sewed the head onto the torso.
Step 13: Glyph
With white yarn
Rnd1: Magic circle 5
Rnd2: 2sc in first 4 sc , 3sc in last -11st(s)
Rnd3: 2sc, sc, sc , 2sc, sc, 2sc, sc, 2sc, sc, 2sc, sc -16st(s)
Rnd4: sc, sc, 2sc, sc, sc, sc, 2sc, sc, sc, sc, 2sc, sc, sc, sc, 2sc, sc -20 st(s)
Rnd5: sc in first 7 sc, 2sc, sc in next 9 sc, 2sc, sc in next 2 sc -22 st(s)
Rnd6: sc, sc, 2sc, sc in next 10 sc, 2sc, sc in last 8 sc -24 st(s)
Rnd7: sc in sc -24st(s)
Rnd8: sc in next 7, sc2tog, sc in next 10, sc2tog, sc in next 3 -20 st(s)
Rnd9: sc in next 3, sc2tog, sc in next 9 sc2tog, sc in next 6 -16 st(s)
Rnd10: sc, sc2tog, sc in next 3, sc2tog, sc in next 3, sc2tog, sc in next 3, sc2tog, sc in next 2 -11 st(s)
Rnd11: sc2tog, sc , sc2tog, sc , sc2tog, sc ,sc2tog, sc in next 2,sc2tog, sc -5 st(s)
Place the light inside and put the stuffing around it. Cut out pieces of felt like in image 5 and glue onto the crochet ball. Don't forget the little bow tie, which I attached with some thread.
