MeDuino: Automatic Medicine Reminder !!
Introduction: MeDuino: Automatic Medicine Reminder !!
About: A Computer Science and Engineering student and a Hobbyist. love to make robots,electric devices,diy things and Programming them by Myself. My youtube channel https://www.youtube.com/fussebatti Follow me on ...
We all need to take medicine at some time. Also we do need to look after our
Parents or Elderly and Giving Medicine in time is the most Important task,specially when they are Anti-biotics. I thought to make one for my mother. I feel relieved that even when i'll not be around her my AUTOMATIC MEDICINE REMINDER: MEduino will take care of her. //Love you Mother.
Teacher Notes
Step 1: Parts You'll Need
  • Arduino pro mini -5v 16mHz
  • Buzzer 330r/220 /1k resistor
  • Vero board
  • Female pin
  • LED's
Step 2: Principle
I have wanted to make this as simple as possible. So I didn't use any RTC
clock module but I've used arduino delay function to work.
24 hours = 24 * 60 minutes
= 24 * 60 * 60 seconds
= 24 * 60 * 60 * 1000 miliseconds (1sec = 1000mili second)
= 86400000 ms
After restarting the Arduino it waits for 24 hours and then keeps on buzzing. Change the delay as your requirement. It won't stop until you press the restart button, which means you have to get to your medicine box in order to stop the alarm. And after you press the button it'll again alarm after 24 hours.
Step 3:
The Circuit diagram is too simple. Take a vero board (dot/line) and solder all
the components on the board. It should look something like this (see picture).
Step 4: Code
Code:
Upload the following Code and upload it to Arduino pro mini. To program arduino pro mini you need to use USB to TTL converter but you can also use your Arduino Uno as Usb Usb to TTL Converter.
we don't have a USB programming option on pro mini. Use a USB to TTL converter or use an ARDUINO UNO. We all have an UNO right? So why waste money?
just remove the ATmega328P ic from arduino uno using a screwdriver to lift it up. the connect the pin as following UNO -------- Pro mini
5v---------------vcc
Gnd------------Gnd
tx----------------tx
rx----------------rx
reset----------- rst
Then Upload the Code
/* MediCinuino: Automatic Medicine reminder.
* By Ashraf Minhaj www.ashrafminhajfb.blogspot.com * For any query mail at ashraf_minhaj@yahoo.com * * Use this and you'll never miss your medicine. * * This is made for my Mother - Sahida Rahman. * I LOVE YOU MOM. */
const int blue = 3; // Connect BLUE LED to pin 3 int buz = 2; // Buzzer on pin 2
void setup() { // initialize the LED & Buzzer pin as Output: pinMode(blue, OUTPUT); pinMode(buz,OUTPUT); }
void loop() { tone(buz,1000,100); //Beep for 1 second- Starting Sound delay(86400000); /*delay 24 hrs. untill next period to take med. * 24hr * 300s * 1000ms */ goto buz; //going to buz: goto Statement
buz: { digitalWrite(blue, HIGH); //Blue led on delay(100); digitalWrite(blue,LOW); //LEd off --thus BLINK delay(100); tone(buz,1000,150); //Start beeping delay(1000); goto buz; /*going again to buz: so that the Code runs untill you come near the Medicine Box and Push the reset switch*/ } }
Step 5: Finish
Now Attach the MEduino on Medicine box and power it up. Further updates can be
made.
Thank You. Happy Making.
Be the First to Share
    • Trash to Treasure Contest
    • Raspberry Pi Contest 2020
    • Wearables Contest
      Wearables Contest
    2 Discussions
    Matlek
    Matlek
    1 year ago
    Very nice, it can be very useful. You could also add a magnetic door switch: so when the box is opened, the timer is reset automatically!
    Ashraf Minhaj
    Ashraf Minhaj
    Reply 1 year ago
    Thanks a lot for pointing out about the automatic reset. I have a reed switch but still I forgot that :( . Thanks Matlek
