Introduction: Measure the Moisture Content of Your Firewood With a Multimeter
If you heat with wood you are probably aware that you should only burn wood that has a moisture content of 20% or less. Of course you can buy a firewood moisture meter for about 50 dollars, but why do that when you probably have one already.
This instructable will show you how to measure the moisture content of your wood and come to a decision as to whether your wood is burnable safely in your stove.
All you need is a multimeter capable of measuring 10 megaohms, higher is better. A few brad type nails and a template with holes 1.25 inches apart. I made mine from wood but paper might almost work better.
Step 1: Why You Should Care About the Moisture Content of Your Wood
Burning wet wood in your wood stove or fireplace insert can lead to creosote build up in your chimney, resulting in reduced draft and possibly a chimney fire. At best it can require more frequent cleaning.
It also reduces the heat produced from your burning wood since the heat produced is wasted vaporizing the water trapped in the wood rather than heating your home.
The image is from a YouTube video of a real chimney fire. Nothing you ever want to deal with.
Step 2: How Wood Moisture Meters Work
Most wood moisture meters work by measuring the resistance of the wood. The resistance is a measure of the conductivity of a material. Conductivity cal be thought of as the ability for electrons to flow through a material. The higher the conductivity, the lower the resistance.
The water trapped in a piece of wood will have salts and nutrients dissolved in it that will allow electrons to flow through the water and conduct electricity. Pure water has a reisistance of 18 megaohms and is a fairly good resistor.
Most wood moisture meters have sharp metal electrodes that are driven into the wood. The resistance between the electrodes will give an indication of the amount of moisture in the wood.
Commercial meters like the one pictured are calibrated to convert their resistance reading to percent moisture content but we don't have to do that. You can have the one in the picture for about 50 dollars.
Step 3: The Resistance of Wood Correlated to Moisture Content
This table is from a US forest service publication which investigated various commercial moisture meters. It is fairly informative but the important information for us is this table. It shows the resistance values of different kinds of wood at different moisture contents. I have highlighted the column for 20% moisture content.
From the table we can see that for most common North American hardwood any resistance above 5 megaohms will indicate a moisture content of 20% or below. A resistance of 10 megaohms will make this statement true for most wood.
Reference: Electric Moisture Meters for Wood, US Forest Service. Author William L. James. General Technicl Report FPL-GTR- 6, 1988.
Step 4: Measuring the Resistance of Your Firewood
The distance between the electrodes is crucial for this experiment. The distance between the electrode used in the table is 1.25 inches. I made a template out of scrap plywood, drilling two small holes this distance apart.
For electrodes I used brad nails and drove them into the wood using the template as a guide. The template lifted off the nails afterwards. Set your multimeter to the resistance setting and touch the two nails. Since we are measuring resistance in the megaohms scale the resistance of the two nails will be negligible in our result.
If you have clip on attachments for your multimeter they will help but aren't necessary
Note that the water may be in layers between the grain of the wood and as you drive the nails deeper you can be sure your wood is drier and there isn't one layer of your wood hiding moisture. You also don't want to do this if it is raining because the surface moisture will negate your results.
The article I reference suggests driving the nail in 1/5 to 1/4 of the thickness of your piece you are measuring.
Before burning you can remove the nails.
