Mesmer-eyes: Rainbow Vortex Slider
99,637
152
28
Introduction: Mesmer-eyes: Rainbow Vortex Slider
Watch the video to see waves of beautiful colors blending and sliding into a colorful vortex (first 2 minutes). The remainder of the video explains how to build one.
With just 2 CDs and a flashlight, you can create beautiful mesmerizing rainbow patterns. I saw a demonstration that used a single CD and I absolutely loved it. I then added a second CD and it blew my mind. It felt like I was being pulled into a vortex of color. I've never seen anything like it. I originally designed this contraption to create psychedelic Alice in Wonderland cat eyes for Halloween, but my kids would rather mask out the bottom of the eyes to create a more spooky face instead. It's also great for parties and festivals.
The device makes it easy to swap CDs for quick experimentation. A written CD looks different than a blank. And even different blank CDs will vary. The mesmerizing patterns are created by simply sliding the light and CDs on the rails. The build uses cheap hardware store materials, but is still robust and precise.
Supplies:
Purchased Materials:
Common/Scrap Materials:
  • 2x CDs with clear cases
  • bit of plywood ⅜" or thicker
  • 14" of 3/4" thick wood at least 2" tall
  • 4" of metal strapping
  • Packing tape & hot glue
  • 4" of thin material like vinyl siding
Tools:
  • utility knife
  • drill press, countersink bit
  • hot glue gun
  • screwdrivers, pliers, measuring tape, square
  • safety glasses
Step 1: Festival Reactions
I wasn't thinking about festivals when I designed it, but it's a perfect fit! It easily draws a large crowd of people that want to see the effects, but also laugh at the expressions of people experiencing the rainbow vortex. To make it easy to wander around with, I added a piece of 3/4" wood and handle that allows me to rest it on my shoulder and aim it like a rainbow bazooka towards anyone that wants to see it. This also left my one hand free to slide the middle CD back and forth creating those mesmerizing patterns.
I probably showed it to 300+ people and everybody enjoyed it. See the video for some fun reactions. My friends were sleeping so people filmed their friends. I'll capture more HQ reactions at Halloween.
Step 2: ​Create Clear CDs
Make a small slit right at the edge of the CD and then use packing tape to remove all the reflective surface. Don't worry if there's a bit of residue or scratching - it's just character of the disc and will make different patterns. You can use rubbing alcohol, don't overdo it - it will dampen the colors. You can also use a DVD disc if you carefully split it with a knife.
Step 3: Create the Base and Rails of the Slider
Drill two ½" holes into some ¾" wood pieces. Center the holes 3.5" apart. Cut the threaded rod to 18" or more and cut the ½" pex 2 ¼" less than the threaded rod length. Slide and rotate the threaded rod into the pex. The threaded rod gives strength and precision while the pex gives a uniform low friction surface. If you cut one piece of pex short, add a washer. Insert the exposed threaded rod into the base plates and fasten with ½" nuts. Tips in annotations.
Step 4: Cut the CD Sled Platform
Separate a CD case into three parts. Cut the bottom case layer to 3" wide measuring from the hinge pivot side. I'd recommend a chop saw or utility knife. If you use a chop saw, go real slow and flip the CD case around before cutting through the plastic against the fence to prevent a bad split. Trim the melted plastic with a knife.
Step 5: Create Sled Skis
Measure and cut 2 pieces of ¾" PEX to 3". These will become the CD sled's skis. Make a mark a ½" away from both ends. If you can, make your marks along side printing on the tube to help with aligning your marks. Then use a scratch awl or center punch to prepare for drilling with a ⅛" bit. Drill out the marks.
Use a utility knife to cut out the bottom 3rd of the sled ski opposite the drilled holes. Watch for knife slips and trim if needed.
Flip the sled ski over and counter sink through the pilot holes from the inside. Spend extra time here so that after you insert screws into the counter sunk holes, the threads will be close to perpendicular to the pex body. You also want to make sure that the screw heads are recessed so that they don't rub on the red pex rails. Push both skis onto the pex rails. Initially the skis will be loose on the rails, but they will tighten up in around 20 minutes. Tips in annotations.
Step 6: CD Sled Platform
Square up the sled skis then place the sled platform on top. Use a speed square to check that the platform is centered. The rail to platform edge distance should be the same for both sides.
Scratch each hole's center onto the platform. Fully support the platform to prevent it from flexing during drilling. Drill slowly!!! I tried going moderately fast one time and the plastic split and shattered very badly. Insert the machine screws into the counter sunk holes and tighten on the nuts.
Place the skis back onto the rails and then secure the platform onto the rails with more nuts. You can oversize the platform holes if needed. If the nuts aren't sitting flush, you can insert a rubber band piece as a washer to prevent cracking the platform.
Step 7: Making the Hinged CD Support
The video is really helpful to watch for this section.
Re-attach the CD case top layer. Bend one end of the copper wire into a hook and check that it fits into the preformed CD case slot. Remove it from the slot and then make two bends that will transition the copper wire from the outside of the case towards the end nut. Finally, bend an L angle opposite the hook end and trim it so that the L can slide on the platform past the end nut.
Step 8: CD Case Hinge Tilt Adjuster
Cut out a piece of vinyl siding J channel with the slot. It doesn't need to be vinyl. Any thin strong material that hot glue sticks to will work. Trim the piece so that it fits alongside the platform lip when the bolt is in the channel. The vinyl should slide freely back and forth.
Ensure the hinge is perpendicular to the rails. Move the vinyl ¼" away from the edge of the platform and tighten in place with a nut. This will later allow the hinge angle to be adjusted in either direction without the vinyl protruding past the platform. Lay out a bead of hot glue over the flat part of the copper onto the vinyl. After about 30 seconds, rotate the copper enough to break free of the hot glue bond. The copper will be held in place, but rotate freely.
The copper hook in the preformed slot needs to restrained. Squirt in some hot glue and rotate the copper wire slightly while the glue dries.This will hold the hook in place, but allow rotation.
Step 9: Cutting Out the Disc Grippers
Place the CD jewel case middle piece flat and score multiple times around the disc gripper on both the front and back side. Use garbage discs to prevent the case from flexing and cracking while scoring the back side. Use pliers to wiggle and snap along the score lines. Repeat until you have just the circular gripper. Trim any sharp edges with a knife.
Step 10: Attaching the Grippers
On the inside of the hinged case piece, temporarily tape on a disc where you want it to serve as a guide for alignment. Then on the case outside, place double sided tape around the inner circle. Insert the disc gripper into a clear CD, line up with the disc on the other side, and then press the gripper into the two sided tape. You can then remove the temporary taped on alignment disc. Additional detail in annotations.
Step 11: Flashlight Sled
Repeat the sled making procedure with wood this time then drill a small hole in the platform face center. Cut out the additional small pieces that make the flashlight support and hot glue together. Insert a screw with any kind of washer into the platform face hole, then slide the flashlight support channel over the screw. Pre-drill two holes into the top of the flashlight support and use metal strapping to fasten the flashlight in place. To test the alignment of the flashlight, slide a piece of paper into the CD case art holder tabs, mark the center and slide sled back and forth. The light should be centered around the marking. The flashlight support channel cut out allows for vertical and horizontal alignment when rotated. Tighten the screw that attaches the flashlight support to the platform when satisfied.
Step 12: Final Thoughts
The part that I had the most trouble with was countersinking the holes into the ¾" pex pipe. The first skis that I made had screws that extended through the hole at varying angles. I had to oversize the CD sled platform holes and it worked fine, but I think we can do better. Next, I'm going to try hot gluing the screws to the pex and forget about countersinking. I did a quick test and it looked very promising.
When I first showed it to a group of friends, I was kinda worried because each person has to line up with the device to get the full mesmerizing effect, but it turned out to make it even more interesting! A few people would be looking from different angles and enjoying the neat patterns, but the person in the vortex beam would exclaim "woahhhhhh!!!" spiking everyone else's curiosity. The viewing zone increases with distance from the machine, but if someone is close enough, you can give them their own private show even if they are surrounded by people. See the reactions video above in step 1 - they are hilarious :)
I took the Rainbow Vortex with me to a camping folk festival (yes, I've got some inner hippy) and it was a huge hit! This instructable went viral going from 300 to 83,000 views in one day! People loved it and I had a massive amount of fun showing it off. I'm looking forward to seeing the next round of Rainbow Vortex iterations.
Thanks for reading :)
Colors of the Rainbow Contest
Runner Up in the
Be the First to Share
    • Mason Jar Speed Challenge
    • Bikes Challenge
      Bikes Challenge
    • Remix Contest
      Remix Contest
    28 Discussions
    curiosity36
    curiosity36
    1 year ago
    I tried different colors of LED with unsatisfactory results. The sensational refraction needs white light. I put together a similar contraption based on your 'ible. I had intended to use the motorized drawer from an optical but stumbled on a short sled left over from a previous project so I started there. I also mounted only one skinless disk. Just hand held the 2nd disk to observe changes in patterns. Also tride various bits of glass and plastic in front of the LED. It was fun to see the changes. Nothing is permanent in my set up, tale & hot glue, so I still may try the motorized drive drawer, or a longer sled at a later date. Thought about housing it all in a traditional oat meal container in order to block out ambient light. We'll see.Thanks for the fun.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    Thanks for sharing your results! I do like the idea of housing it in a container of some kind. One day I'm going to try housing it in 5" air ducting, but it will require a complete redesign. Not sure if you saw the video of me taking it to a festival, but it's good for some laughs: https://youtu.be/SQ8HX-S4fEM
    curiosity36
    curiosity36
    Reply 1 year ago
    Yes, I did see the video. Looked like everyone was amused and having a good time with Mesmer-Eyes. I did add a black background with just the single LED sticking thru. The background eliminated a lot of interfering light.
    AussieAlf
    AussieAlf
    1 year ago
    Hey afraser-kruck, that is sooo cool, fantastic visual effects there.
    Good luck with the comp.. I recon you have it in the bag.
    Cheers.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    I won a nice mug prize pack and received a lot of positive feedback :) The Instructable went viral and hackaday liked it saying "It’s a build of a kind we haven’t seen before". In any case, I think you might enjoy seeing the device in action at a music festival: https://www.youtube.com/watch?v=SQ8HX-S4fEM some really funny reactions. Cheers!
    AussieAlf
    AussieAlf
    Reply 1 year ago
    Geez is that all...i recon you got short changed there. I would have given it to you by a long shot.
    BTW, they are good quality mugs. I use mine all the time, perfect size for a big bloke like myself.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    Thanks for the kind words. Glad you like it!
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    Thanks! I added a video of it in use at a festival. See step 1. It's pretty fun :)
    jagmeet_hanspal
    jagmeet_hanspal
    Reply 1 year ago
    that video with original reactions is even more awesome!
    krispa
    krispa
    1 year ago
    Awesome!
    DigitalDaveG
    DigitalDaveG
    1 year ago
    Excellent project and excellent clear video!
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    afraser-kruck
    afraser-kruck
    Tip 1 year ago
    I got some great suggestions at the festival:
    1) we should try using LaserDiscs as they are like huge record sized CDs and should have the same amazing effects only bigger.
    2) one person suggested adding a small water gun to the bottom of the Rainbow Vortex Slider near the front so that you can give people a gentle squirt of water in the face while they are mesmerized. Kinda like that "smell my rose" prank, or some 3D movies. This could be really really fun :)
    steveturri
    steveturri
    1 year ago
    How big of a projection does it make at max range where the effect is still good quality? As you mentioned for a halloween prop, I was curious how big it could get.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    Just to clarify, it does project some, but you get the crazy effects when looking directly into it. You can see the crazy patterns at least 20 feet away if you are lined up. Projecting through it might be possible with some modifications, but you'd need a very powerful light source & battery to project anything of a significant size. Something like a standard video projector. I've added a video to step 1 showing it in operation at a festival. I'm still planning to use it for Halloween. I'll probably aim it at people because it's great fun to interact, but I might have it slowly panning back and forth or have a "stand here" sign.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    I'm out at a festival right now. I'll do some detailed measurements when I'm back and I'll post here.
    curiosity36
    curiosity36
    1 year ago
    Very clever. Cool effect. Next step? Motorize the slide, drive with Arduino. Focused RBG?
    Your little project stirs the juices. Thanks for posting.
    afraser-kruck
    afraser-kruck
    Reply 1 year ago
    I agree!!! I'm actually really excited to try an RGB light with this. Combining a color shifting light with a motorized slide... it has to happen. I did try it with a pure red light and I only saw the red part of the rainbow during all the sliding. I think you'll be able to choose which ring or rings of color you want to see. I just got some neopixels. Do you think they would work? Our did you mean a quad lead RGB LED?
    RussellRohde
    RussellRohde
    Reply 1 year ago
    Same thing went straight into my head. I have the arduinos, steppers, drivers, 2x2 and 4x4 WS2812B sitting around. It is school holidays now so I think the lego technic will be coming out and I'll do a proof of concept with the kids (or without the kids)
