Introduction: Minecraft Block Light
Minecraft Block light
Wood(1/8 Hardboard panel), Plexiglass, sandpaper, drill, jigsaw or wood chisel, wood glue or hot glue, saw to cut the wood
Step 1: Cut the 6 12'' Squares
Step 2: Make a Line Every 3/4" on Both Sides So You Get 16x16 Squares
Step 3: Cut Out the Squares So the Lights Can Go Through
I used a drill in the middle of the squares then I used a wood chisel and file to make it square
Step 4: Put the Sides Together and Use Tape to Keep the Shape and Then Glue the Inside So You Cant See Glue
Step 5: Next Paint It. I Used a Stone Grey Spray Paint
Step 6: Next Take the Plexiglass and Sand It on One Side So You Cant See Through It
Step 7: Glue the Plexiglass Into the Block Over the Squares You Cut Out
Step 8: Next Add Led Strips Inside of the Cube and Then But the Last Piece
Step 9: There Is the Finished Minecraft Block
Fandom Contest
