Introduction: Minecraft PE - Mini RMS Titanic Tutorial
Hello, and welcome to this tutorial on how to build the RMS Titanic, but on a small scale. I hope you enjoy the tutorial, and please post a comment below if you have any troubles or questions.
Step 1: Layer One - Lay the Keel
This step is very simple - you lay a 22 block long keel 2 blocks under the water, and you put 16 blocks on both sides.
Step 2: Layer Two - Make the Under Hull
Now, this step is very simple if you follow the pics
Step 3: Layer Three - Above Water Hull Part
Now, this part is also very simple, just follow the pictures and you will be okay.
Step 4: Layer Four - Upper Works
This step is also very easy if you follow the pics.
Step 5: Layer Five - Upper Works Part Two
So, for this step you just add a bit more upper works, and a deck.
Step 6: Layer Six - Little Details
This step is also very easy - use quartz slabs and make the bridge, and some other stuff from the pic.
Step 7: Layer Seven - Funnels
The funnels are very simple - they're just four 2 - high gold sticks with dark oak wood slabs on top, and with 2 block separation.
Step 8: Propellers and Rudder
Just follow the pics.
Step 9: Masts
The mast on the front is 5, blocks high, and the mast on the back is 4 blocks high.
Step 10: And... You're Done!
I hope you like this tutorial very much!
Please leave some feedback, and a favorite!
And if you want, please hit that subscribe button!
Peace!
