Introduction: Mini Charcoal Furnace
It's easy and quick to make, I will show in this instructable the steps on how to make it using materials some of us have in our house. The only "big" money might be the refractory materials and characoal.
A few details about my furnace: I made it all 2" thick around including the furnace lid. I used Plywood, MDF, cardboard, chipboard all left overs from other jobs.
The furnace tools I made from a 5mm construction rebar, can of beans and old bathrooms hooks.
In the near future I hope to add to this instructable a few images of my first sand casting.
A few Saftey words: Coming into contact with fire and boiling melted metal can be very dangerous so always work safe using proper full body protection including respirator mask against toxic fumes and dust from mixing refractory materials. Never melt in a wet area or near water, if water comes in contact with the boiling aluminium it might "blow" in your direction.
Step 1: Furnace Construction
I used scraps of plywood, MDF, chipboard, soft wood, cardboard all screwed together.
Start with the walls and the base. Optional: making small wooden angles for the corners will make the corners flat preventing them from breaking.
Drill a hole 2" from the base using a core bit for timber. The diamater of the hole should fit the size of the pipe you will use for the blower.
I used a cardboard pipe to form the opening for the blow pipe.
Step 2: Furnace Core
Step 3: Furnace Top
Step 4: Furnace Lid
Strips of 5mm MDF will do for holding the rebars in place and will be very easy to snap off in the stripping stage. Screw the MDF into place, mark the hole positions and drill the holes.
I bent 5mm rebars to serve as handles for the lid. Place the handles in the holes and leave a 20mm gap from the base.
Step 5: Furnace Refractory
In the third image you can see 2 bits of ply attached to the inside walls of the furnace, they will be stripped of later and the gap left in the material will be a good handle grip for lifting the furnace.
Start from the base of the furnace and drill the copper pipe to the base center point, after that using a block of timber etc. compact the refractory and remove of all unwanted air bubbles.
Drill the center screw out and leave the copper pipe in its place. Attach the plastic can with the same screw in the center over the refractory.
Cover all sides around the plastic can with the refractory mix and compact as you go.
When you get near the top place the cover and secure it with timber to the furnace plywood walls.
When all is compacted well and covered use a hammer to tap on the plywood sides to get rid of any remaining air bubbles.
(I will not go into details regarding the mixing ratio of refractory so if anyone wants to make somthing similar that will last longer check other sites for proper refractory materials mixing and exact measuring ratio's).
I just used cement+sand+fireclay and a small amount of water just turning it into a nice paste. It will probably crack at some stage but I'm sure I will get a few nice melting before that.
I also recommend placing a wire mesh between the core and furnace walls that will help against cracks.
Step 6: Removing Furnace Frame
Start taking the screws out and removing the sides of the furnace, you can use a chisel or such but don't wedge and pull it against the furnace.
The cardboard can be taken out with one finger, once it is wet it wont stick.
All the scrap you can throw away or use to make another furnace.
Step 7: PATIENCE, LET IT DRY!!!
While waiting I did a bit of aluminum experiment to cheak how hot it gets using my multimeter, nut cracker and camping propane cooker. In the images you can't see the flame but look at the temperature (celsius) on the multimeter screen The nut cracker melted in less then 5 min.
Step 8: Furnace Tools
Crucible: Is the container that holds the aluminium parts before melting them and for casting them in sand or just into an aluminium ingot.
The professional ones are made from different materials such as clay graphite, silicon carbide and more. They can be purchased from as little as a few bucks to couple of hundred.
The crucible I used in this instructable is worth about 2$ - such a bargain..he..he.
In retrospect:
I don't recommend using tin cans at all, it can be dangerous, I got a few ingots out of it but one corn can I used broke inside the furnace with big holes.
I made the crucible from a used can of beans v shaping the lip for easy pouring, I drilled 2 holes to the sides of it and placed 2 bolts to act as lifting pins.
On the bottom I tied steel wire with a loop at the end.
The lifting fork and hook I made from 5mm construction rebar that I welded to an unused bathroom hook.
I also bought a 94c muffin tray (another bargain) to make some ingots.
The rebars are long enough to keep a safe distance from the boiling aluminium and your body.
Step 9: On the Menu
Step 10: My First Aluminium Ingot
Step 11: This Was a Fun Experiment !!! Some Conclusions
This was a great experiment for first time aluminium casting.
Hope you enjoyed my instructable.
This is a short video I made, I know its not great and my hand is in the way and a bit of slag fell into the muffin tray but it gives the general idea of ingot making.
