Mini FPV-Rover
Introduction: Mini FPV-Rover
About: Like to make stuff
This is a mini version of my FPV-Rover V2.0
https://www.thingiverse.com/thing:2952852
The dimension are 10cm x 10cm x 3cm
Teacher Notes
Step 1: Parts to Print
Find all parts you need on Thingiverse
https://www.thingiverse.com/thing:2478547
1x body
70x track
70x rubbertrack (only if needed)
1x top
2x inner track frame
2x outer track frame
4x cog
Step 2: Parts You Need (BOM)
Here is the list with all necessary parts for the rover
8x bearings
2x motor (300rpm)
2x ESC
8x Screws M3x14mm
1x Receiver (if you use FRSKY)
1x FPV AIO Camera
1x Rubberband to secure the camera
8x Magnets 4mm x 2mm
1x Battery 1S 600mAh
1x Drill 1.8mm
1x Drill 1.9mm
Step 3: Assemble the Mini FPV-Rover
As the Mini FPV-Rover has not that much to assemble, I hope the pictures are enough
Step 4: Done
Have fun with the Mini FPV-Rover
Be the First to Share
    • Backyard Contest
      Backyard Contest
    • Silly Hats Speed Challenge
    • Finish It Already Speed Challenge
