Mini Lighthouse Lamp
1,586
10
Introduction: Mini Lighthouse Lamp
About: I am IT professional, living in Bangalore, India. As new gadgets come out everyday, we indulge in spending significant time and money on these gadgets. And our kids are learning from us, they know how to use...
Hi All,
I love decorating my house with an unconventional or "one of the kind" idea and reuse / recycle items found at home. In this instructable , I will be reusing old glass jar, wooden skewers, Whiskey bottle packages, popsicle sticks and cardboard ( from Shirt packaging)
I will be use different techniques in this article and it should be safe for beginners to replicate.
Please share your comments and feedback
Step 1: What Do We Need ?
Materials
  • Cardboard Cylinder ( 3.75" diameter and 12" height)
  • Pebbles or small construction stone
  • Popsicle sticks
  • Skewers
  • 0.5" Plywood
  • 5mm MDF sheet
  • 0.5W LED bulb
  • B22 Bulb Socket
  • 3ft Copper wire
  • 2 pin AC plug
  • Black Thread
  • White cement
Tools
  • Hot Gule gun
  • Black, white and brown acrylic paint
  • Wood polish
  • Drilling machine
  • Jigsaw
  • Hacksaw
  • G Clamps
  • 2mm and 35 mm drill bits
  • PVA glue or Fevicol
Step 2: The Tower
  • Before starting sort the pebbles or construction stones by
    • Size
    • Shape
    • Thickness
  • This is important as this reduces time spent on finding the right stone for the space
  • To make window and Door frames, I used longer stones, I arranged them on my table first and then ot glued them on the cardboard cylinder
  • Then fill the space between the window and the door
  • Next fill the top and bottom borders, This makes it easier when finishing
  • Fill in the gaps.
  • Depending on the quality of your hot glue gun and glue sticks, the stones may fall randomly. Just be patient and glue them back
  • I coated a thin layer of white cement to fill in between spaces
  • Let it dry for 3 to 4 hours
  • The white cement also covers stone, which is undesirable, use dry brush technique to regain the natural stone colors
  • I used diluted black acrylic paint with very less paint in the brush to cover the stones
Side Note : I first tried using white cement and placing stones, but was careless and whole thing just fell off
Step 3: The Top
  • I am making this part using cardboard, that I recovered from Shirt packaging material
  • Since my tower is now 4" diameter after stone work,
  • I cut a 4.5" diameter, cardboard circle
  • Then cut a piece at 110 degree and fold it carefully to make a cone
  • Use paper tape to join it
  • I tried coating with thin layer of white cement, but it fell off, So covered it with more paper tape
  • This size is based on the glass bottle that I will describe in the next step
Step 4: Lantern Glass
One could have used small jar too, I could not find one at my home so decided to cut a larger jar to size that i wanted
  • This was an olive jar bottle, that I cut using my bottle cutter.
  • I scored the jar at appropriate length
  • Then using Candle and ice method, cut the bottle into 2
  • Using 220 GRIT sandpaper, smooth out any sharp edges
  • I am using the bottom piece and the saving the top of the jar for another project in future
  • Cut a piece of baking paper and stick it inside the glass jar, this will help in defusing light further
Step 5: Lantern: Base
  • On a 5mm MDF plank, cut a 4.5" circle using jigsaw
  • Drill 2mm holes (8) at the border for railing or fences
  • Drill 2mm Drills (4) to secure the glass from outside
  • Drill a hole of 30mm at the center ( image in next steps) for the bulb to fit in
  • Fit skewers of suitable length for glass jar and fences
Step 6: Lantern Base Fitting
  • To fit the lantern on the base tower, we need a "inside cap" arrangement
  • First we drill a 35mm hole 15mm plywood
  • Cut its corners to fit inside the tower as shown
  • Now using PVA glue o fevicol, stick the base board from previous step to this inner cap piece
  • Also before glueing, I have inserted the first piece on a bulb holder, on which we can fit the remaining part of the bulb holder
  • Clamp the arrangement for drying
Step 7: Wiring
  • Insert a wire from the back of the tower
  • connect bulb holder and a 2 pin AC plug
  • Check if the connections are not loose
  • Insulate any wires or connectors, where needed
Step 8: Finishing
Windows and Door
  • Based on the size and shape of the window and door, cut cardboard piece as shown
  • Using popsicle sticks cover them
  • Cut the excess
  • Stain the popsicle sticks with brown paint
  • Then coat wood polish on them
  • Hot Glue the wind and door on the tower as shown
Lantern Fences and Base
  • Paint the base, skewers and top with brown acrylic paint
  • Coat them with wood polish
  • Using black thread make fence ropes
  • The thread may expand in future and fall off from their position
  • So secure them in place by using pva glue or fevicol
Tower
  • By now many pebbles or stone must have dropped due to bad hot glue
  • Hot glue them in place again
Step 9: Light It Up
  • Since this lamp uses 0.5 W LED bulb, it does not get hot even after 8 hrs.
  • Due to stone it get a bit heavier and stable. cannot be
  • To change bulb, just lift the Glass jar and change the bulb
  • If you are replacing the bulb, we may have to open the top for the heat to dissipate, just like actual lighthouse
Find a suitable spot to place your new lamp and Light it up
Please share your comments and suggestions
Be the First to Share
    • Puzzles Speed Challenge
    • Secret Compartment Challenge
    • Lighting Challenge
      Lighting Challenge
