Introduction: Mini Piano With Arduino 101
This is a mini piano board with only 4 customizable buttons allowing you to play any frequency and tone you want. It is a simple yet fun toy to build especially for kids!
Here's also a recording of my happy birthday-twinkle twinkle Arduino remix!
Step 1: Materials and Tools
- Arduino
- 4x Push button switches
- 4x 10kΩ resisitor
- 6x jumper wires
- Breadboard wires
- Breadboard
Step 2: Connecting to Ground
- Connect one of the pins of each of the switches to ground.
- Connect one of the buzzer pins to ground.
It doesn't matter which one you connect since the remaining pin will be the signal pin.
Step 3: Connecting the Resistors
- Connect each of the 10kΩ resistor between power (red power rail) to one of the pins of each switch, this is also known as the signal pin.
- Connect this power rail to 3.3V.
Step 4: Connecting the Signal
- Connect the signal pin of each switch to pins 2-5 on the Arduino.
Step 5: Coding and Uploading
Upload the following code to your Arduino, once you have selected the appropriate board and port under tools.
const int yellow = 2;
const int green = 3; const int blue = 4; const int red = 5; const int buzz = 6;
int notes[] = {262,294,330,349};
void setup() { pinMode (yellow, INPUT); pinMode (green, INPUT); pinMode (blue, INPUT); pinMode (red, INPUT);
pinMode (buzz, OUTPUT); tone (buzz, 2000); Serial.begin(9600); }
void loop() { if (digitalRead(yellow) == LOW) {tone(buzz, notes[0], 50); delay (50); noTone(buzz); Serial.println(digitalRead(yellow));}
else if (digitalRead(green) == LOW) {tone (buzz, notes[1], 50); delay (50); noTone(buzz);} else if (digitalRead(blue) == LOW) {tone (buzz, notes[2], 50); delay (50); noTone(buzz);} else if (digitalRead(red) == LOW) {tone (buzz, notes[3],50); delay (50); noTone(buzz);} else noTone (buzz); }
Step 6: Demo
Makerspace Contest 2017
